[postgis-users] raster loading and ST_Value performance
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Wed Sep 19 07:51:08 PDT 2012
> Q1: What effect does different tile size have on storage and performance?
Biggest tiles = longer to load in memory and less efficient indexing
I suggest you experiment with much smaller tiles: 100x100 and 10x10
> Q2: We will need to be getting raster values from a large number of
> point tables over a large number of raster tables. Is there any method
> to speed up the queries?
If your rasters are all of the same size and cover the same footprint I would suggest to make them different bands of the same raster. So for the same point you will search for the right tile only once.
Pierre
