[postgis-users] unique id in QGIS/PostGIS
pcreso at pcreso.com pcreso at pcreso.com
Sat Apr 6 15:37:51 PDT 2013
Hi again,
In your screencap your SRID seems to be set to zero. Even if the data displays in QGIS, it will not be in the correct place, unless you have this set correctly. So with the unique index/prikary key - you still probably won't see the data unless you zoom the that layer extent.
I have scribbled out a quick Linux script which uses the shp2pgsql command to load the shapefile, & which creates the unique index automatically... I'm not certain I got the SRID correct - so it will be worth checking.
HTH,
  Brent Wood
#! /bin/bash
# script to load Legislative_shape.zip & create unique index
SHP=Legislative_final_shapefile/Legislative_Final.shp
# create new, empty Postgres database
dropdb test
createdb test
# install postgis
psql -d test -c "create extension postgis;"
# determine projection
# assume from these links that the SRID is 3559 -
#   I couldn't find one to match the prj file directly
# http://planning.maryland.gov/msdc/S5_Map_GIS.shtml
# http://www.spatialreference.org/ref/sr-org/3559/
# load the shapefile the easy way...
# use -I to create the primary key
shp2pgsql -s 3559 -I $SHP legislative_final | psql -d test
--- On Sat, 4/6/13, Margie Roswell <mroswell at gmail.com> wrote:
Subject: [postgis-users] unique id in QGIS/PostGIS
To: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Date: Saturday, April 6, 2013, 9:18 PM
I've been googling up a storm, now that I've got a local postgis database with QGIS. But still haven't figured out how to display a newly created table.
The query I used to create the table:
CREATE TABLE smaller_leg_final AS
SELECT ST_Buffer(geom,-500)  AS geom, legislative_final.district
FROM legislative_final
WHERE area > 30;
I then discovered that I needed a unique ID, and did the following:
ALTER TABLE smaller_leg_final ADD COLUMN id serial not null;
This successfully populated the ID field with unique integers.
However when I go into QGIS, the Primary Key column offers no options. when I click into it, it just asks me to choose an SRID, which I believe I've already done. The table loads, but nothing displays.
I honestly feel a bit like a toddler given ice skates and placed on an icy rink. I'm toddling my way around, falling, getting back up, and then looking up and asking: why did I fall?
Once upon a time I was at the true cutting edge of GIS... I purchased MapInfo versions 1.1, and upgraded from there for many years. Moving into QGIS/Posgres/postGIS now, and well on the path to success, but .... not... quite... there.
Are there any QGIS users here who can help me to display my new table?
Do I need a different postgres statement? Is there a different field name expected? Maybe my query generated invalid shapes... But still, the geom field is displaying in the "Add PostGIS layers "Geometry column", but the Primary key column option doesn't allow me to select my 'id' field.
Insight welcome.
--http://FarmBillPrimer.orghttp://www.BaltimoreUrbanAg.org (Please send events; This site is hungry.)
http://www.ExcellentNutrition.org
http://www.packtpub.com/drupal-5-views-recipes/book
On Thu, Apr 4, 2013 at 11:21 AM, Lelo - Luiz Rogério De Pieri <lelo.pieri at gmail.com> wrote:
Hi all,
I'm having a problem to execute a pgsql2shp command using java.
My OS is Ubuntu and it's frequently I use to generate shp files using pgsql2shp, but now I want to do it through java.
The follow command works fine on terminal
pgsql2shp -f pontos_05600202_teste -h myhost -u myuser -P mypasswd -g coordinates my_database "SELECT * from points where id_uploaded_file = 37995";
Now I'm trying to execute the follow code:
ProcessBuilder pb = new ProcessBuilder("pgsql2shp", "-f pontos_05600202_teste", "-h myhost", "-u myuser", "-P mypasswd", "-g coordinates", "my_database", "SELECT coordinates, date from points where id_uploaded_file = 37995");
Process proc;
proc = pb.start();
InputStream stdin = proc.getInputStream();
InputStreamReader isr = new InputStreamReader(stdin);
BufferedReader br = new BufferedReader(isr);
String line = null;
System.out.println("<OUTPUT>");
while ((line = br.readLine()) != null)
    System.out.println(line);
System.out.println("</OUTPUT>");
int exitVal = proc.waitFor();
System.out.println("Process exitValue: " + exitVal);
And the result is:
<OUTPUT>
Preparing table for user query... Done.
Initializing...  coordinates: no such attribute in table __pgsql2shp14493_tmp_table
</OUTPUT>
Does anybody as any idea about it?
Thank you for all
Best regards
Rogério De Pieri  (Lelo)SCJP 5
Buscando melhorar a cada dia
Áudio, Hardware & Softwarewww.twitter.com/lelopieriblogdolelo.wordpress.com
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130406/db3aad82/attachment.html>
