[postgis-users] Problems installing on Linux
James David Smith james.david.smith at gmail.com
Mon Aug 5 10:15:13 PDT 2013
Hi there,
I'm trying to make and compile PostGIS 2.0 with PostgreSQL 9.0. My
verrsion of PostgreSQL is:
 PostgreSQL 9.0.4 on x86_64-unknown-linux-gnu, compiled by GCC gcc
(GCC) 4.1.2 20080704 (Red Hat 4.1.2-48), 64-bit
A work colleague and I havee been following the steps here:
http://postgis.net/docs/postgis_installation.html
However when we try to do this command it fails:
psql -d james_test -f /usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql
The messages we get are all similar to this:
psql:/usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql:4783: ERROR:
 current transaction is aborted, commands ignored until end of
transaction block
Could the problem be that Postgis 1.5 is still installed/present? I
ask, as if I run the following command itseems to work fine:
psql -d james_test -f /usr/pgsql-9.0/share/contrib/postgis-1,5/postgis.sql
Any ideas? By the way, I appreciate that the ideal solution might be
to upgrade PostgreSQL to 9.1 but having got this far I'd like to try
and 'finish' this if possible.
Thanks
James
