[postgis-users] error with global/pg_filenode.map
Tung Thanh con500thoi at yahoo.com
Mon Aug 19 06:32:10 PDT 2013
Dear List
Thank you very much for help and very useful comments, I have some problem with the Ubuntu system I am working, because it is a "live server". It is very difficult to reboot. Do you have the others ways to solve this problem.
Thank you very much
Tung
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Sent: Thursday, August 15, 2013 5:28 AM
Subject: Re: [postgis-users] error with global/pg_filenode.map
That usually denotes a locked file not closed.  Usually
resolves if you reboot your whole server or the postgresql
service.
We describe the issue here:
http://www.postgresonline.com/journal/archives/203-postgresql90-yum.html
(though this article is a bit dated)
except
If you get a:
FATAL: could not open relation mapping file
"global/pg_filenode.map": Permission denied When you attempt to connect
to psql. Most likely the problem is caused by a locked file from left over. You
could go thru the effort of shutting down things looking, for what went wrong,
but you are an Almost idiot with little patience for these things.
just do a:
reboot
and all should be fine.
Leo and Regina
http://www.postgis.us
http://www.paragoncorporation.com
http://www.bostongis.com
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Tung
Thanh
Sent: Wednesday, August 14, 2013 3:37 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] error with
Dear
List
I
am installing software name geo-node, on the way of installation I have some
errors with postgresql/postgis and psycopg2
I
have also removed and re-install postgresql and python-psycopg2 many time but It
doesn't work
the
problem when  I installed by using command as bellow
$sydi
add-apt-repository xxxx
$sudo
apt-get update
$sudo
apt-get install geonode
and
the errors occurred:
Traceback
(most recent call last):
File "/var/lib/geonode/bin/django- admin.py", line 5, in <module>
  management.execute_from_ command_line()
File "/var/lib/geonode/lib/python2. 6/site-packages/django/core/
management/__init__.py", line 443, in execute_from_command_line
  utility.execute()
management/__init__.py", line 382, in execute
  self.fetch_command(subcommand) .run_from_argv(self.argv)
management/base.py", line 196, in run_from_argv
  self.execute(*args, **options.__dict__)
management/base.py", line 232, in execute
  output = self.handle(*args, **options)
management/base.py", line 371, in handle
  return self.handle_noargs(**options)
File "/var/lib/geonode/lib/python2. 6/site-packages/south/
management/commands/syncdb.py" , line 90, in handle_noargs
  syncdb.Command().execute(** options)
management/commands/syncdb.py" , line 57, in handle_noargs
  cursor = connection.cursor()
File "/var/lib/geonode/lib/python2. 6/site-packages/django/db/
backends/__init__.py", line 308, in cursor
  cursor = util.CursorWrapper(self._ cursor(), self)
backends/postgresql_psycopg2/ base.py", line 177, in _cursor
  self.connection = Database.connect(**conn_ params)
File "/usr/local/lib/python2.6/ dist-packages/psycopg2/__init_ _.py", line 179,
in connect
  connection_factory=connection_ factory, async=async)
psycopg2.OperationalError:
FATAL:  could not open relation mapping file "global/pg_filenode.map": No
such file or directory
FATAL:
 could not open relation mapping file "global/pg_filenode.map": No such
file or directory
Traceback
  utility.execute()
management/commands/loaddata. py", line 71, in handle
in connect
FATAL:
file or directory
Site
default disabled.
To
activate the new configuration, you need to run:
service apache2 reload
Considering
dependency proxy for proxy_http:
Module
proxy already enabled
Module
proxy_http already enabled
Enabling
site geonode.
To
Restarting web server apache2
           ... waiting
       [ OK ]
Stopping Tomcat servlet engine tomcat6
                  [ OK ]
Starting Tomcat servlet engine tomcat6
                  [ OK ]
           ... waiting .
Any
ideas to fix
Many
thanks
@QT
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130819/eaeb6ec4/attachment.html>
