[postgis-users] PostgreSQL + PostGIS 2.1.0 Tiger Geocoding notworking
Paragon Corporation lr at pcorp.us
Mon Aug 26 03:48:16 PDT 2013
There was a bug in the 2.1.0 one that made it not work in  PostgresQL 9.2
and below since I accidentaly used 9.3 features.
http://trac.osgeo.org/postgis/ticket/2441
and I describe a bit here
http://www.postgresonline.com/journal/archives/317-CREATE-SCHEMA-IF-NOT-EXIS
TS-in-9.3-and-tiger-geocoder.html
Sorry about that. Can you try the one packaged in the latest 2.1.1.  If you
can't build on your own, its packaged in the latest windows 2.1.1dev (just
copy the postgis_tiger_geocoder .* files in share/extension folder)
 http://postgis.net/windows_downloads (you might need to get rid of the
windows line breaks)
If you want you can even use the 2.2.0dev one which does Tiger 2013 (data
just came out a couple of days ago) instead of Tiger 2012.  I've been using
it the 2013 for MA and so far so good but need to stress test some more.
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
  _____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Tom C
Sent: Monday, August 26, 2013 1:58 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostgreSQL + PostGIS 2.1.0 Tiger Geocoding
notworking
Did you add the fuzzy string match extension?
On Monday, August 26, 2013, René Fournier wrote:
So
 I've done a clean/fresh install of PostgreSQL 9.2 and PostGIS 2.1.0 via
MacPorts (thanks Vincent). Installed the requisite extensions:
CREATE EXTENSION postgis;
CREATE EXTENSION postgis_topology;
CREATE EXTENSION postgis_tiger_geocoder;
Tested the basics:
gc5=# SELECT na.address, na.streetname,na.streettypeabbrev, na.zip
gc5-# FROM normalize_address('1 Devonshire Place, Boston, MA 02109') AS na;
 address | streetname | streettypeabbrev |  zip
       1 | Devonshire | Pl               | 02109
(1 row)
Then, to get the data (Tiger 2012), generated the loader script and ran it:
gc5=# SELECT loader_generate_script(ARRAY['MA','RI'], 'sh') AS result;
Bash script downloaded and added Massachusetts and Rhode Island without
complaint, also ran:
SELECT install_missing_indexes();
But when I try to geocode or reverse geocode, I get nothing:
gc5=# SELECT g.rating, ST_X(g.geomout) As lon, ST_Y(g.geomout) As lat,
        (addy).address As stno, (addy).streetname As street,
        (addy).streettypeabbrev As styp, (addy).location As city,
(addy).stateabbrev As st,(addy).zip
        FROM geocode('75 State Street, Boston MA 02109') As g;
 rating | lon | lat | stno | street | styp | city | st | zip
There's clearly a lot of data in my geocoder DB:
 gc5         | postgres | UTF8     | en_CA.UTF-8 | en_CA.UTF-8 |
| 1194 MB | pg_default |
But I can't get anything from it
 My previous 1.5.x PostGIS tiger geocoder
was working fine
 I must be missing something obvious. Can anyone point it
out for me?
Rene
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130826/1fd238a4/attachment.html>
