[postgis-users] ST_MinkowskiSum
Stephen Mather stephen at smathermather.com
Sat Dec 7 20:41:12 PST 2013
Hmm, partially answering my own question, but it's obvious the output is
not 2D, but I can't say I quite understand the product it is creating... .
Best,
Steve
On Sat, Dec 7, 2013 at 5:55 PM, Stephen Mather <stephen at smathermather.com>wrote:
> Hit send too soon...
> Hi All,
> Digging SFCGAL... .  Quick question-- is ST_MinkowskiSum a 2D calculation
> of the Minkowski Sum when non-polyhedral surfaces are fed in?  For example,
> I tried this:
> WITH pointt AS (
> SELECT ST_MakePoint(0,0,0) AS the_geom
> buffered AS (
> SELECT ST_Buffer(the_geom, 30, 20) AS the_geom FROM pointt
> rotatedOnItsSideX AS (
> SELECT ST_RotateX(the_geom, 0.25 * pi()) AS the_geom from buffered
> minkowski_sum AS (
> SELECT ST_MinkowskiSum(x.the_geom, b.the_geom) AS the_geom FROM
> rotatedOnItsSideX x, buffered b
> SELECT ST_AsText(the_geom) from minkowski_sum;
> I get:
> MULTIPOLYGON(((-60 -7.45012945754965e-14,-59.9075200119938
> -2.35377287183542,-59.8150400239877 -4.01814163088313,-59.538170229848
> -6.35740271025471,-59.2613004357083 -8.01151008244411,-58.8017478297844
> -10.3218370469144,-58.3421952238606 -11.9554849102494, (...)
> Thanks,
> Best,
> Steve
> On Sat, Dec 7, 2013 at 5:51 PM, Stephen Mather <stephen at smathermather.com>wrote:
>> Hi All,
>> I tried this:
>> WITH pointt AS (
>> buffered AS (
>> minkowski_sum AS (
>> SELECT 1 as gid, ST_AsText(the_geom) from minkowski_sum;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131207/64ff7a42/attachment.html>
