[postgis-users] functions
tommaso tommasodb at googlemail.com
Mon Dec 9 23:32:44 PST 2013
Why do you do ST_AsText(e.geom)::geometry? This is equivalent to e.geom.
Change the query so:
SELECT e.gid, e.geom FROM electric_line e, fuses f WHERE
ST_DWithin(e.geom, f.geom 0.01) AND f.gid=$1 .....
No sure if it does help, but you you can also try so:
SELECT e.gid, e.geom FROM electric_line e JOIN fuses f ON
ST_DWithin(e.geom, f.geom, 0.01) WHERE f.gid=$1
Also
WHERE ST_DWithin(ST_EndPoint(f.geom),ST_StartPoint(n.geom),0.01)
can be changed to:
WHERE ST_Distance(ST_EndPoint(f.geom),ST_StartPoint(n.geom)) <= 0.01
which should be faster.
Obviously you need a GIST index on booth geometry columns.
If it all does not help please attach some test data.
Cheers, Tommaso
On 12/10/2013 03:01 AM, Jonatan Malaver wrote:
> Another question, what can I do to improve performance on the query?
> The query can take 2 seconds or more.
> *From:*postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Jonatan
> Malaver
> *Sent:* Monday, December 09, 2013 8:52 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] functions
> Thank you!!!
> Jon
> [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of *tommaso
> *Sent:* Monday, December 09, 2013 12:57 PM
> This should work:
> create or replace function flow(integer) RETURNS TABLE (gid int, geom
> geometry, geojson text) AS
> WITH RECURSIVE flow(gid, geom) AS (
> ST_DWithin(ST_AsText(e.geom)::geometry, ST_AsText(f.geom)::geometry,
> 0.01) AND f.gid=$1
>   UNION ALL
>     SELECT n.gid, n.geom
>     FROM electric_line n, flow f
> SELECT *, ST_ASGeoJSON(ST_Transform(geom,4326),6) AS geojson
> FROM flow;
> LANGUAGE SQL;
> SELECT * FROM flow(1);
> On 12/09/2013 03:57 PM, Jonatan Malaver wrote:
>     Hello,
>       I'm new to postgis/postgresql. I was wondering if anyone could
>     tell me how to make a function out of this sql query:
>     ST_AsText(f.geom)::geometry, 0.01) AND f.gid=' . $_GET['fuse'] . '
>       UNION ALL
>     FROM flow;
>        I'd like to make a function flow(gid)
>     Thanks,
>     Jon
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131210/20ea59bb/attachment.html>
