[postgis-users] Old question resurfacing
Gerry Creager - NOAA Affiliate gerry.creager at noaa.gov
Tue Dec 10 11:42:15 PST 2013
Remi, Bborie
Thanks. I'll look now.
gerry
On Tue, Dec 10, 2013 at 11:49 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> If your radar return is well discretized in time (I'd say max 10^6
> points/sec),
> pointcloud could do the trick (you can have any number of attributes per
> point).
> Else, you would have to cut the data into pieces.
> Cheers,
> Rémi-C
> 2013/12/10 George Silva <georger.silva at gmail.com>
>> I'm glad this might work out for you.
>> I'm not familiar with the products you guys generate or store, but you
>> can even store rasters with more then one band, keeping all the data in a
>> single place, but different bands.
>> On Tue, Dec 10, 2013 at 3:15 PM, Gerry Creager - NOAA Affiliate <
>> gerry.creager at noaa.gov> wrote:
>>> Raster is always a possibility, but we lose some data therein. If I use
>>> what we refer to as "Level III" data, then it's certainly a potential. I'm
>>> sorta thinking of using Level II data which comprise
>>> azimuth/range/elevation and one of: reflectivity, radial velocity or
>>> spectrum width (standard deviation of velocity). The programmatic results
>>> of this, creating new Level III data products, are big.
>>> Thanks for the suggestion. Simply taking it to raster hadn't, honestly,
>>> occurred to me because I was overthinking some aspects of the problem.
>>> gerry
>>> On Tue, Dec 10, 2013 at 11:00 AM, George Silva <georger.silva at gmail.com>wrote:
>>>> If you transform it to rasters PostGIS Raster can handle them already.
>>>> Now, about the new datatype, I'll let the experts discuss :P.
>>>> Cheers
>>>> On Tue, Dec 10, 2013 at 2:52 PM, Gerry Creager - NOAA Affiliate <
>>>>> I asked this years ago, and I think Paul was less than pleased with me
>>>>> (:-), but:
>>>>> Has anyone, in the ensuing years looked at encoding radar data into a
>>>>> postGIS database? We've a little idea that might benefit one project, and
>>>>> getting the radar data into a good geospatial format would be
>>>>> beneficial.The data, of coure, would start out as radial-distance and
>>>>> intensity from the radar site, although we could preprocess it by gridding.
>>>>> Thanks, Gerry
>>>>> Gerry Creager
>>>>> NSSL/CIMMS
>>>>> 405.325.6371
>>>>> “Big whorls have little whorls,
>>>>> That feed on their velocity;
>>>>> And little whorls have lesser whorls,
>>>>> And so on to viscosity.”
>>>>> Lewis Fry Richardson (1881-1953)
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>> George R. C. Silva
>>>> SIGMA Consultoria
>>>> http://www.consultoriasigma.com.br/
>>> Gerry Creager
>>> NSSL/CIMMS
>>> 405.325.6371
>> George R. C. Silva
>> SIGMA Consultoria
Gerry Creager
NSSL/CIMMS
405.325.6371
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131210/a649e0c1/attachment.html>
