[postgis-users] Export data from postgis db to OSM-like format?
Maks Vasilev max at stranger-team.ru
Fri Dec 13 22:04:49 PST 2013
First task to use normalized osm-like format - it's convert it to navigator
format using mkgmap.
14.12.2013 9:51 пользователь "Stephen Woodbridge" <woodbri at swoodbridge.com>
написал:
> On 12/14/2013 12:32 AM, Maks Vasilev wrote:
>> Hi!
>> I'm use postgis base for mapnik rendering osm geo data and i have a
>> parralel task to convert this data to other format.
>> In database i have big update and conversion sql/pl_pgsql procedure to
>> normalization raw osm data before to render it. And task chain
>> osm->postgis->(normalization)->mapnik works fine.
>> How to export geo data from my normalyzed postgis database to osm-liked
>> data?
> What do you plan to do with the data in this "osm-like" format?
> If you want to load it into OSRM then look at there normalized ffile
> format the osrm-extract generates.
> -Steve W
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131214/a3236875/attachment.html>
