[postgis-users] ST_RotateX with pointOrigin!
Stephen Mather stephen at smathermather.com
Sat Dec 14 19:57:13 PST 2013
Ahem-- bugs fixed:
-- Function: st_rotatex(geometry, double precision, geometry)
CREATE OR REPLACE FUNCTION ST_RotateX(geomA geometry, rotRadians
double precision, pointOrigin geometry)
  RETURNS geometry AS
$BODY$
----- Transform geometry to nullsville (0,0,0) so rotRadians will take
place around the pointOrigin
WITH transformed AS (
    SELECT ST_Translate(geomA, -1 * ST_X(pointOrigin), -1 *
ST_Y(pointOrigin), -1 * ST_Z(pointOrigin)) AS the_geom
----- Rotate in place
rotated AS (
    SELECT ST_RotateX(the_geom, rotRadians) AS the_geom FROM transformed
----- Translate back home
rotTrans AS (
    SELECT ST_Translate(the_geom, ST_X(pointOrigin),
ST_Y(pointOrigin), ST_Z(pointOrigin)) AS the_geom
    FROM rotated
----- profit
SELECT the_geom from rotTrans
$BODY$
  LANGUAGE sql VOLATILE
  COST 100;
On Sat, Dec 14, 2013 at 8:37 PM, Stephen Mather
<stephen at smathermather.com> wrote:
> Hi All,
> I think I avoided doing linear algebra, which is good since I never
> studied it... .
> This is my cludgy patch for making a version of
> geometry ST_RotateX(geometry geomA, float rotRadians, geometry pointOrigin)
> It's not pretty enough to be a real patch ('cause my brain couldn't do
> that whole linear algebra thing, and hence why it's here and not the
> developers list), but thought I'd share it anyway and get impressions,
> and have some brighter minds make sure I don't have some major logic
> failure here:
> DROP FUNCTION st_rotatex(geometry,double precision,geometry);
>   RETURNS geometry AS
> $BODY$
> rotated AS (
>     SELECT ST_RotateX(the_geom, rotRadians) FROM transformed
> rotTrans AS (
>     SELECT ST_Translate(geomA, ST_X(pointOrigin), ST_Y(pointOrigin),
> ----- profit
> $BODY$
>   COST 100;
