[postgis-users] How can I create a point at a known distance & bearing from a point in Postgis?
Brent Wood pcreso at pcreso.com
Sun Dec 15 08:57:23 PST 2013
Thanks David - I do indeed...
Cheers,
Brent
To: Brent Wood <pcreso at pcreso.com>; PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Sent: Sunday, December 15, 2013 6:08 PM
Subject: Re: [postgis-users] How can I create a point at a known distance & bearing from a point in Postgis?
On Sun, Dec 15, 2013 at 2:52 PM, Brent Wood <pcreso at pcreso.com> wrote:
>Hi,
>I
 have a dataset with start & end points that we are represtnting as
linestrings. Many records do not have endpoints - so we are takimg the
median bearling for comparable startpoints & creating an arbitrary
endpoint.
>While it is easy to get a bearing for a known endpoint
with ST_Azimuth(), is there a simple way in Postgis to get the point at a
 defined distance & bearing? I've perused the docs & nothing
jumped out as an obvious solution.
Sounds like you need ST_Project()
Regards
David Rowley
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131215/a5528657/attachment.html>
