[postgis-users] help with the Union of 2 shp
J.Alejandro Martinez Linares islanis at infomed.sld.cu
Mon Dec 16 12:01:03 PST 2013
El 16/12/13 14:38, Rémi Cura escribió:
> And of course it is *a very bad idea* to try something without knowing
> if it works on all your data !
> You should try the complete solution on a small sample, then optimize
> your queries, then use it on all your data...
> Cheers,
> Rémi-C
ok ok, but there are 6570 rows of multipolygons, ok what can i do?, at
least i need to know if the entire process is working, i mean like a
progress bar, is there enything like that??!!! please and thanks
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131216/29543ab8/attachment.html>
