[postgis-users] GeometryCollection with GEOMETRYCOLLECTIONM, POINTM etc.. value in constructor.
Baris Ergun barisergun75 at gmail.com
Sat Dec 21 11:31:49 PST 2013
I have tested the issue with latest snapshot 2.1.0SVN for  jdbc driver. The
GeometryCollection still cannot parse the String value correctly. There is
a similar issue in postgis extension source codes.
http://trac.osgeo.org/postgis/ticket/724
So with the Java based jdbc codes it looks like we hit the same case. If I
could report this as a bug to trac I would do it right away but I dont have
access to there.
On 21 December 2013 11:57, Baris Ergun <barisergun75 at gmail.com> wrote:
> Hi Remi;
> Who should I get in touch about this issue related to
> org.postgis.GeometryCollection constructor in postgis jdbc driver.
> Thanks.
> On 18 December 2013 10:53, Baris Ergun <barisergun75 at gmail.com> wrote:
>> Exactly correct. I also tried to tell that the problem was originated
>> from org.postgis.GeometryCollection constructor. So I posted to here to
>> understand why constructor was behaving like this. This constructor is in
>> postgis-jdbc.jar . Anyone knowing about this problem on
>> the org.postgis.GeometryCollection constructor?
>> On 18 December 2013 10:35, Rémi Cura <remi.cura at gmail.com> wrote:
>>> Hey,
>>> using this in sql :
>>> SELECT ST_AsText(ST_GeomFromText(
>>> 'GEOMETRYCOLLECTIONM(
>>> POINTM(10 10 100),
>>> LINESTRINGM(0 50 100, 100 50 100),
>>> POLYGONM((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45
>>> 100,55 45 100,55 55 100,45 55 100,45 45 100))
>>> It gives you the expected output.
>>> I would guess it is the java function you are using that is faulty (the
>>> geometrycollection constructer).
>>>  Cheers,
>>> Rémi-C
>>> 2013/12/18 Baris Ergun <barisergun75 at gmail.com>
>>>> Hello
>>>> I create a GeometryCollection as below
>>>> GeometryCollection coll = new GeometryCollection(
>>>>                             "SRID=-1;GEOMETRYCOLLECTIONM(POINTM(10 10
>>>> 100),LINESTRINGM(0 50 100, 100 50 100),POLYGONM((25 25 100,75 25 100,75 75
>>>> 100,25 75 100,25 25 100),(45 45 100,55 45 100,55 55 100,45 55 100,45 45
>>>> 100)))"));
>>>> when I reprint the coll.toString() I see that my geom string is changed
>>>> to below :
>>>> "SRID=-1;GEOMETRYCOLLECTIONM(POINT(10 10 100),LINESTRING(0 50 100, 100
>>>> 50 100),POLYGON((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45
>>>> 100,55 45 100,55 55 100,45 55 100,45 45 100)))"
>>>> As you can see GEOMETRYCOLLECTIONM is preserved but POINTM LINESTRINGM
>>>> and POLYGONM is changed to POINT LINESTRING and POLYGON . And because of
>>>> this I get cannot mix dimensionality when I am trying to insert this geom
>>>> to database.
>>>> I have tried this with postgis jdbc driver 1.1.5; 1.3.3 and 2.0.1
>>>> versions.
>>>> This is a test written in datanucleus orm for geospatial extensions and
>>>> the test is run against the below table (create script) in postgresql db.
>>>> CREATE TABLE public.samplepggeometrycollectionm
>>>>   samplepggeometrycollectionm_id integer NOT NULL DEFAULT
>>>> nextval('samplepggeometrycollectionm_samplepggeometrycollectionm_id_seq'::regclass),
>>>>   geom geometry(GeometryCollectionM),
>>>>   id bigint NOT NULL,
>>>>   name character varying(255),
>>>>   CONSTRAINT samplepggeometrycollectionm_pkey PRIMARY KEY
>>>> (samplepggeometrycollectionm_id)
>>>> WITH (
>>>>   OIDS=FALSE
>>>> ALTER TABLE public.samplepggeometrycollectionm
>>>>   OWNER TO postgres;
>>>> Awaiting ur suggestions.
>>>>  Baris
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Barış
>> www.linkedin.com/in/barisergun
> Barış
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131221/5cd7c221/attachment.html>
