[postgis-users] GDAL problems (Kyngesbury GDAL)
William Kyngesburye woklist at kyngchaos.com
Sat Dec 28 16:48:52 PST 2013
Is there a crash report in Console.app from when you try to load GDAL python?  It will probably be as python.
On Dec 28, 2013, at 6:27 PM, Dheeraj Chand wrote:
> William,
> Thanks for responding. I was using the 1.10 because I updated when you updated. I got the same kind of error when I used 1.9, though.  I'd be more than happy to try again and show you, though. Do you think that it's necessary?
> Best,
> -dx
> On Dec 28, 2013, at 11:46 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> Sorry, I didn't read to the very end, where you did recompile with the --include-dirs option.
>> The missing lib/ warning is no problem, just a warning.
>> The segfault though, doesn't say enough to figure out what's wrong.  Maybe there is something in the Console.app, like a crash report (User Diaognostic Reports section).
>> On Dec 28, 2013, at 11:38 AM, William Kyngesburye wrote:
>>> The compile flag to set the GDAL include dir is wrong for the framework.  It seems to be assuming that the framework is a 'nix lib/include structure, but really the include dir is named "Headers".  Odd that it uses supposedly gdal-config, but doesn't get the -cflags from it that have the correct include dir.
>>> I see that Tim's instructions actually call for using --include-dirs=/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/
>>> I wonder: Tim, what is it about the "virtual environment" that makes the existing GDAL python in the framework not work? (I don't know anything about python virtual env)
>>> On Dec 27, 2013, at 10:33 PM, Dheeraj Chand wrote:
>>>> Hi, all,
>>>> I was working on a project, that at a high level, can be described as :
>>>> 1. Connect Python to PostGIS,
>>>> 2. Grab spatial tables' data,
>>>> 3. *PROCESS*,
>>>> 4. Spit out shapefiles.
>>>> In the process of doing this, I was trying to use the Python GDAL library in a new virtualenv called geo, but I got these errors.  I am using William Kyngesbury's GDAL 1.10 for OS X, and I'm running into crazy errors.  I am following the instructions from here (http://linfiniti.com/2013/02/installing-python-gdal-into-a-python-virtualenv-in-osx/), and this is what happened in my shell.
>>>> Can anyone help me out?
>>>> Best,
>>>> -dx
>>>> (geo)REINHEIT:GDAL dheerajchand$ python
>>>> Python 2.7.3 (v2.7.3:70274d53c1dd, Apr  9 2012, 20:52:43)
>>>> [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)] on darwin
>>>> Type "help", "copyright", "credits" or "license" for more information.
>>>>>>> from osgeo import gdal
>>>>>>> gdal.__version__
>>>> Segmentation fault: 11
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
