[postgis-users] ST_SetSRID
laurent lcelati at latitude-geosystems.com
Thu Feb 21 02:36:49 PST 2013
Hello,
SELECT postgis_full_version()
"POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER"
Yes, yesterday i tried to do a reprojection thanks to st_transform & to do a
ST_SetSRID in order to update metadata but eventually I do not think I
succeeded.
Could you tell me the SQL query please? I thought that following queries are
valid :
SELECT rast As bd_ortho, ST_Transform(rast,4326) As bd_ortho_wgs84
But i have today an error message saying :
ERREUR:  la colonne « rast » n'existe pas
LINE 1: SELECT rast As bd_ortho, ST_Transform(rast,4326) As bd_ortho...
Once I'm sure I reprojected this layer, I will try to update the metadata
Thank you to throw light for me.
Regards.
View this message in context: http://postgis.17.n6.nabble.com/ST-SetSRID-tp5002645p5002650.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
