[postgis-users] How can I optimize a raster in postgis 2 for display?
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Thu Feb 28 08:22:49 PST 2013
The QGIS PostGIS raster plugin use GDAL to read rasters stored in PostGIS. I guess (but this is still not clear to me as I use OpenJump, not QGIS, to display vectorizations of PostGIS rasters), the last development version of the GDAL driver supports overviews. So:
1) Find out which version of GDAL your QGIS installation is using (I have no idea how and it depends on your platform).
2) Make sure to load your rasters with overviews. There is unfortunately no way yet to build overviews for already loaded raster tables. You will have to reload with the right option.
Pierre
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of Ivan Santiago
> Sent: Thursday, February 28, 2013 11:13 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] How can I optimize a raster in postgis 2 for display?
> Hello all:
> I ran rtpostgis.sql to enable postgis raster to our gis db.
> Thanks for the advice, Pierre.
> Now...
> Two rasters were added to the new database
> but I have problems viewing them in QGIS using the available plugin.
> plugin: Load Postgis Raster to QGIS Ver 0.0.5.4
> Original size erdas img files: 32mb, and 379mb
> raster_columns view:
> "gisogp";"ambiental_geologia_rasters_cuadrangulos";"o_6_ab_geol_20k";"rast
> ";32161;6;-6;128;128;t;f;3;"{8BUI,8BUI,8BUI}";"{255,255,255}";"{f,f,f}";
> "gisogp";"ambiental_topografia_rasters_mdt";"o_6_ab_ele";"rast";32161;6;-
> 6;128;128;t;f;1;"{32BF}";"";"{f}";
> "gisogp";"ambiental_topografia_rasters_mdt";"ab_ele";"rast";32161;1;-
> 1;128;128;t;f;1;"{32BF}";"";"{f}";
> "gisogp";"ambiental_geologia_rasters_cuadrangulos";"ab_geol_20k";"rast";321
> 61;1;-1;128;128;t;f;3;"{8BUI,8BUI,8BUI}";"{255,255,255}";"{f,f,f}";
> The main problem with these rasters is the extremely slow performance in QGIS.
> Maybe the problem lies in QGIS and not in postgis raster.
> gvSIG does not support postgis 2.0 as far as I know.
> Then, how can I optimize a raster in postgis 2 for display?
> OS: CentOS 5
> PG version: 2.0.2
> PSQL vers:  9.2
> Iván Santiago
> GIS Specialist
> Information Technologies
> Office of Management and Budget
> 787.725.9420 x 2378
> Calle Cruz 254
> PO Box 9023228
> San Juan, PR 00902-3228
> bounces at lists.osgeo.org] On Behalf Of Pierre Racine
> Sent: Monday, February 25, 2013 5:51 PM
> Subject: Re: [postgis-users] Postgis raster question: how to enable raster type in
> 2.0
> rtpostgis.sql if for loading raster definition and function into the database. Not
> to upgrade.
> http://postgis.net/docs/manual-
> dev/postgis_installation.html#create_new_db_extensions
> <http://postgis.net/docs/manual-
> dev/postgis_installation.html#create_new_db_extensions>
> http://postgis.net/docs/manual-dev/postgis_installation.html#upgrading
> <http://postgis.net/docs/manual-dev/postgis_installation.html#upgrading>
> Pierre
> > From: postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-
> bounces at lists.osgeo.org>  [mailto:postgis-users-
> > bounces at lists.osgeo.org <mailto:bounces at lists.osgeo.org> ] On Behalf Of
> Ivan Santiago
> > Sent: Monday, February 25, 2013 3:22 PM
> > raster type in
> > 2.0
> > Turns out it raster support was installed.  I made another DB without
> > enabling postgis extension which includes raster.
> > I hope that solves the problem. Still need to load a raster to see if this worked.
> > Did you load rtpostgis.sql?
> > It looks like rtpostgis.sql is for upgrading postgis. would you
> > recommend me to run it?
> > we are on version 2.0.2
> > Iván Santiago
> > GIS Specialist
> > <https://mail.ogp.gobierno.pr/exchweb/bin/redir.asp?URL=https://mail.o
> > gp.go bierno.pr/exchweb/bin/redir.asp?URL=http://www.ogp.gobierno.pr/>
> > 787.725.9420 x 2378
> > Calle Cruz 254
> > PO Box 9023228
> Pierre Racine
> > Sent: Monday, February 25, 2013 4:06 PM
> > raster type in
> > 2.0
> > Pierre
> Ivan Santiago
> > Sent: Monday, February 25, 2013 1:42 PM
> > To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> > Subject: [postgis-users] Postgis raster question: how to enable raster
> > type in 2.0
> > Hello all:
> > We installed postgresql 9.2 and postgis 2.0 in a CentOS 5 virtual server.
> > after running:
> >  select postgis_full_version();
> > I get the following:
> >  "POSTGIS="2.0.2 r10789" GEOS="3.3.6-CAPI-1.7.6" PROJ="Rel. 4.8.0, 6
> >  March 2012" LIBXML="2.7.6" LIBJSON="UNKNOWN""
> > Raster does not appear.
> > How can I enable raster data type?
> > Thanks in advance.
> > Iván Santiago
> > GIS Specialist
> > 787.725.9420 x 2378
> > Calle Cruz 254
> > PO Box 9023228
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
