[postgis-users] problem with 'sobel' & ST_MapAlgebraFctNgb
Bborie Park bkpark at ucdavis.edu
Fri Jan 18 15:15:07 PST 2013
Hey,
Your sobel function looks fine.  How you're calling it is incorrect
though.  You only have two function parameters defined in the
regprocedure argument of your ST_MapAlgebraFctNgb query.
-bborie
On 01/18/2013 03:10 PM, laurent wrote:
> Hello,
> I would like apply a sobel filter to my raster DEM. In a 1st time, i defined
> the sobel function in a sql.file.
> In a 2nd time, i tried to run the 'ST_MapAlgebraFctNgb'  via PSQL console
> available via pgadmin3.
> When i run the query, i have an error message saying : The "Sobel(float []
> [], text []" does not exist.
> I send you by attachment the 'sobel.sql' & the 'ST_MapAlgebraFctNgb' query.
> Could you throw light for me please?
> Regards.
> IMAGE.
> sobel.sql <http://postgis.17.n6.nabble.com/file/n5002352/sobel.sql>
> Query_ST_MapAlgebraFctNgb.sql
> <http://postgis.17.n6.nabble.com/file/n5002352/Query_ST_MapAlgebraFctNgb.sql>
> View this message in context: http://postgis.17.n6.nabble.com/problem-with-sobel-ST-MapAlgebraFctNgb-tp5002352.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
