[postgis-users] CopyTopology cannot copy a topology that "hasz"
Sandro Santilli strk at keybit.net
Tue Jan 22 10:16:05 PST 2013
On Tue, Jan 22, 2013 at 12:30:42PM -0500, John Morrison wrote:
> Tried to copy a topology created with hasz=true via CreateTopology.
> *temp01=# SELECT topology.CopyTopology('ma_topo', 'ma_topo_copy');
> ERROR:  Geometry has Z dimension but column does not
> CONTEXT:  SQL statement "INSERT INTO ma_topo_copy.node SELECT * FROM
> ma_topo.node"
> *-- $Id: topology.sql.in.c 10644 2012-11-05 10:27:08Z strk $*
> Platform is FC17, PostGreSQL is postgresql-9.1.7-1.fc17.x86_64 (stock FC17
> with updates)
I've the impression this bug was fixed in one of the 2.0.x versions.
Did you properly upgrade ?
Please report output of postgis_full_version();
--strk;
 http://www.cartodb.com - Map, analyze and build applications with your data
                                       ~~ http://strk.keybit.net
