[postgis-users] Postgis 2.0 initial install
Stuart Claggett orcastu at gmail.com
Sat Jan 26 08:02:11 PST 2013
Jeff,
Thank you I will uninstall and try again.  Thanks for the quick response.
Stuart
On Saturday, January 26, 2013 10:59:14 AM UTC-5, Jeff Lake wrote:
>  correct you installed backwards ..
> reinstall PostGIS so it can find GEOS, GDAL and everything else
> *Jeff Lake*
> MichiganWxSystem <http://www.michiganwxsystem.com>
> AllisonHouse <http://www.allisonhouse.com>
> GRLevelXStuff <http://www.grlevelxstuff.com>
> On 1/26/2013 10:52, Stuart Claggett wrote:
> Hello,
>  I am just trying to get started on PostGis and appear to be having some
> issues with my initial install and wondered if anyone could assist.  I am
> running Ubuntu 12.1 on VMware on a Mac.
>  I first had my postgres database installed and then postgis.  I then
> realized after reading some materials I probably need GEOS, Gdal and a few
> other things needed to be installed.  I now have GEOS and Gdal installed
> but when I run SELECT post_gis_full_version();    I just get POSTGIS =
> 2.0.1  whereas in the postgis book I am reading it expects GEOS-CAPI, PROJ,
> LIBXML and USE_STATS.
>  Perhaps I have done the install in an incorrect order.  I simply would
> like to setup a proper environment so I can continue with the book and
> exploring features.  Any suggestions would be greatly appreciated.
>  Thanks in advance to the assistance and I look forward to group
> discussion.
>  Stuart
> postgis-users mailing listpostgi... at lists.osgeo.org <javascript:>http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130126/df934272/attachment-0001.html>
