[postgis-users] ST_AsPNG is problematic in Java
Bborie Park dustymugs at gmail.com
Mon Jun 17 09:57:37 PDT 2013
Ahmet,
Can you try one of the example code found in the docs?
http://www.postgis.net/docs/manual-dev/using_raster_dataman.html#RT_Raster_Applications
By testing out one of the examples, you should be able to tell if the
problem is in the database or in your java code.
-bborie
On Mon, Jun 17, 2013 at 6:04 AM, Ahmet Temiz <ahmettemiz88 at gmail.com> wrote:
> hello
> postgresql (9.2.2)
> postgresql-jdbc 9.2
> here is the result of SELECT postgis_full_version();
>  POSTGIS="2.1.0SVN r10952" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
> 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.8.0" RASTER
> thank you
> On Mon, Jun 17, 2013 at 3:45 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Which JDBC driver are you using and which PostgreSQL version.  You might
>> be affected by the escape/hex change in 9.0
>> detailed here:
>> http://postgis.net/docs/manual-2.0/PostGIS_FAQ.html#id338804
>> ________________________________
>> From: postgis-users-bounces at lists.osgeo.org
>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Ahmet Temiz
>> Sent: Monday, June 17, 2013 8:32 AM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] ST_AsPNG is problematic in Java
>> hello
>> I am dealing with java-jpa2-postgis(raster)
>> I tried to get an image from postgis(raster) as:
>> List list_rast = session.createSQLQuery("SELECT ST_AsPNG(rast) As rastpng
>> FROM geoslp5 where rid=184 ;").list();
>> and converting object to byte[]
>> and
>> with usual java process
>> ByteArrayOutputStream bos = new ByteArrayOutputStream();
>> bytes = bos.toByteArray ();
>> But resulting image file(png) is defective ?
>> What may the probable problems ?
>> Do you have any recommendations ?
>> regards
>> Ahmet Temiz
>> Jeoloji Müh.
>> Afet ve Acil Durum Yönetimi Başkanlığı
>> Planlama ve Zarar Azaltma Dairesi Başkanlığı
>> Ahmet Temiz
>> Geological Eng.
>> Information Systems - GIS Group
>> Disaster and Emergency Management
>> of Presidency
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Ahmet Temiz
> Jeoloji Müh.
> Ahmet Temiz
> Geological Eng.
> of Presidency
