[postgis-users] [OT] How to construct and float8[][] array?
Humberto Cereser Ibanez humberto at pastoraldacrianca.org.br
Fri Jun 28 12:55:31 PDT 2013
Hi Steve,
did you try execute the most nested subquery and the upper one to see
which one causes the ERROR?
There is also an array_cat function that support multidimensional
arrays.
http://www.postgresql.org/docs/9.1/static/arrays.html
best regards,
Em Sex, 2013-06-28 às 14:53 -0400, Stephen Woodbridge escreveu:
> Hi all,
> This is a little bit off topic but I'm trying to create a nxn array like
> the following in SQL:
> {{0,1,2,3},{1,0,3,2},{2,3,0,4},{3,2,4,0}}
> select array_ndims('{{0,1,2,3},{1,0,3,2},{2,3,0,4},{3,2,4,0}}'::float[][]);
> -- 2
> select array_dims('{{0,1,2,3},{1,0,3,2},{2,3,0,4},{3,2,4,0}}'::float[][]);
> -- [1:4][1:4]
> select pg_typeof('{{0,1,2,3},{1,0,3,2},{2,3,0,4},{3,2,4,0}}'::float[][]);
> -- double precision[]
> So I came up with the following:
> select array_agg(arow) as dm from (
>    select i, array_agg(dist) as arow from (
>      select a.source_id as i,
>             b.source_id as j,
>             st_distance(st_makepoint(a.x, a.y),
>             st_makepoint(b.x, b.y)) as dist
>        from tsp_00 a, tsp_00 b
>       order by a.source_id, b.source_id
>    ) as foo group by i order by i
> ) as bar;
> But I get the following error:
> ERROR:  could not find array type for data type double precision[]
> ********** Error **********
> SQL state: 42704
> So the question is how can I construct float[][] object like the
> constant using sql?
> I would like to use this in pgRouting to build a distance matrix and
> pass it to our TSP solver, like:
> select * from pgr_tsp(
>    (select array_agg(arow) as dmatrix from (
>               b.source_id as j,
>    ) as bar),
>    0
> Thanks,
>    -Steve
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
