[postgis-users] Count Points in Polygon with Postgis
Tom van Tilburg tom.van.tilburg at gmail.com
Sun Mar 17 01:11:25 PDT 2013
Hi Carsten,
What you need is a *left join* :
|select grid.gid, count(kioskdhd3.geom) AS totale
FROM grid
LEFT JOIN kioskdhd3
ON st_contains(grid.geom,kioskdhd3.geom)
GROUP BY grid.gid;|
Note that I changed the * in count to a column from your points table
because you only want to count when you have a non-null value in your
points table.
Regards,
  Tom
On 16-3-2013 16:53, Carsten Hogertz wrote:
> I've got a simple problem: I want to count the number of points within
> a set of polygons.
> I have a SQL already but it only gives back the gid of the polygone
> that actually contains points.
> My tables: a polygon layer with 19.000 rows and a point layer with 450
> rows.
> The following SQL
> |select grid.gid, count(*) AS totale FROM grid, kioskdhd3 WHERE
> st_contains(grid.geom,kioskdhd3.geom) GROUP BY grid.gid;
> return only some 320 polygons that actually contain points. But I want
> all polygons returned, even thought the number of points is 0.
> Of course it has to do with my WHERE-clause. Where do I have to put in
> my st_contains?
> Thank you Carsten
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130317/4ba99b9d/attachment.html>
