[postgis-users] flow analysis
Hugues François hugues.francois at irstea.fr
Thu May 16 05:03:35 PDT 2013
Hello,
You may try to work with a dump of your multi into single (st_dump(geom)).geom
Hugues.
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Jonatan Malaver
Sent: Thursday, May 16, 2013 2:01 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] flow analysis
OK, so after some research I found out that ST_StartPoint() returns NULL for multilinestring. Anyone know a work around?
Thanks,
Jonatan
Sent: Thursday, May 16, 2013 7:46 AM
Here's my query
WITH RECURSIVE flow(gid, geom) AS (
    SELECT gid, geom FROM l4_3 WHERE gid = 212
  UNION ALL
    SELECT n.gid, n.geom
    FROM l4_3 n, flow f
    WHERE ST_DWithin(ST_EndPoint(f.geom),ST_StartPoint(n.geom),0.01)
SELECT gid, ST_AsText(geom)
FROM flow;
Here's the result
212;"MULTILINESTRING((589700.21 2926252.04,589698.873744219 2926256.62316697))"
l4_3 is a multilinestring of and electrical circuit. I would like to see what's downstream the grid from a transformer, fuse, or upstream from a house meter.
Thanks,
Jonatan
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Nicolas Ribot
Sent: Wednesday, May 15, 2013 12:55 PM
Hello,
This precise example, no, but the "WITH RECURSIVE" construct yes.
Could you post your query and the data model ?
Nicolas
On 15 May 2013 17:56, Jonatan Malaver <jon.malaver at shrewsburyma.gov> wrote:
	Hello again,
	I tried the example, but it only returns the same line. Has anyone tried that example?
	Thanks,
	Jonatan
	Sent: Tuesday, May 14, 2013 1:02 PM
	The WITH RECURSIVE construct allows to walk a graph:
	This link may help:
	http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html
	Nicolas
	On 14 May 2013 18:40, Jonatan Malaver <jon.malaver at shrewsburyma.gov> wrote:
		Hello, is it possible to do any flow analysis? For example, query postgis for what down flow a certain point?
		Thanks,
		Jonatan Malaver
		postgis-users mailing list
		postgis-users at lists.osgeo.org
		http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130516/117155ad/attachment.html>
