[postgis-users] RE : Need help with update table from a select query
Clifford Snow clifford at snowandsnow.us
Fri May 24 16:10:48 PDT 2013
On Fri, May 24, 2013 at 11:21 AM, Hugues François <hugues.francois at irstea.fr
> wrote:
> You should try :
> update nodes a
> set outline_id = b.outline_id
> from outlines b
> where st_contains(b.geom, a.geom)
> Hugues.
That worked perfectly. I must have been trying to over think the problem.
Thanks
Clifford
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130524/e1170d92/attachment.html>
