[postgis-users] radically different performance on different machines
Richard Greenwood richard.greenwood at gmail.com
Fri Nov 8 06:58:45 PST 2013
I have a query that runs in <1 second on one machine and 47 seconds on
another. The postgres and postgis versions are bascially the same. The
database and query are the same. But "explain" is different on the two. The
query is below and the graphic output of pgAdmin explain is attached.
Obviously, my question is - why the difference?
Thanks,
Rich
select pidn, accountno, owner, address, address2,
       st_address, descript, wkb_geometry, row_number() OVER (ORDER BY
pidn) AS row_number
       from ownership_export,
    (SELECT special_districts.name,
      st_buffer(special_districts.wkb_geometry, (-5)::double precision) AS
geom,
      row_number() OVER (ORDER BY special_districts.name) AS row_number
     FROM special_districts
     WHERE name = 'Teton Village Resort District'
    ) as sd_buffer
where st_intersects(ownership_export.wkb_geometry, sd_buffer.geom);
-- ownership_export is a view: parcel_combined + parcel_attrib
Richard Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131108/b4396f2b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131108/b4396f2b/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131108/b4396f2b/attachment-0001.png>
