[postgis-users] postgresql upgrade from 8.4 to 9.1
Martin Landa landa.martin at gmail.com
Fri Nov 8 09:05:07 PST 2013
2013/11/5 Sandro Santilli <strk at keybit.net>:
> You're likely restoring postgis objects togheter with the data.
> The postgis objects in the old database are meant to be used
> with PostgreSQL 8.4, not 9.1. You need to skip those objects.
> The postgis_restore.pl script was written to do the objects
> skip for you, at restore time.
> By using pg_upgradecluster you're missing the "skip" step
> in the process. You'll have to do the pg_dump/pg_restore manually
> instead, as documented in the "Hard Upgrade" section in the manual.
right, thanks! Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
