[postgis-users] mapserver 6.4.0 can't create geom with postgis 2.1.0?!
Sandro Santilli strk at keybit.net
Sat Nov 9 01:34:41 PST 2013
On Sat, Nov 09, 2013 at 03:02:30AM -0500, BladeOfLight16 wrote:
> On Sat, Nov 9, 2013 at 12:39 AM, John Smith <jayzee.smith at gmail.com> wrote:
> > looks like mapserver 6.4.0 can't create geom with postgis 2.1.0. can
> > someone confirm that before i rollback to ms 6.2.1 or before :( is there
> > any other solution?
> > just trying to connect ms 6.4.0 with pg 2.1.0 but getting the following
> > error:
> > WARNING:  ST_Force_2d signature was deprecated in 2.1.0. Please use
> > ST_Force2D
> > CONTEXT:  SQL function "st_force_2d" during startup
> I don't use MapServer, but that's a warning, not an error. Is that the only
> indication that something is wrong, or are you experiencing a different
> error?
Correct, that's a WARNING, not an ERROR.
Also, upgrading to 2.1.1 would turn that into a DEBUG
(not shown at all, usually).
Please report this also to mapserver developers, they might want to tweak
the code to account to version differences.
--strk;
 ()  ASCII ribbon campaign        - against html e-mail
 /\  http://www.asciiribbon.org   - against proprietary attachments
