[postgis-users] database backup with postgis extension
Paulo Frias pfrias82 at gmail.com
Wed Nov 13 04:34:21 PST 2013
Thanks..
On 13 November 2013 12:34, Paulo Frias <pfrias82 at gmail.com> wrote:
> It works.. ;)
> On 13 November 2013 12:06, Paulo Frias <pfrias82 at gmail.com> wrote:
>> The errors are:
>> pg_restore: [archiver (db)] Error from TOC entry 3978; 1259 35665 INDEX
>> intertidal_line_apt_geom_gist postgres
>> pg_restore: [archiver (db)] could not execute query: ERROR: relation
>> "intertidal_line_apt_geom_gist" already exists
>> and the same for the other data which have geometry.
>> I just have created the new database with:
>> $ createdb -T template0 newdb
>> I didn't add the postgis extension in this new database.
>> but now... I tried with the postgis extension and it gave me the
>> following error:
>> pg_restore: [archiver (db)] Error while PROCESSING TOC:
>> pg_restore: [archiver (db)] Error from TOC entry 7; 2615 34094 SCHEMA
>> topology postgres
>> pg_restore: [archiver (db)] could not execute query: ERROR: schema
>> "topology" already exists
>>             Command was: CREATE SCHEMA topology;
>> any idea?
>> On 13 November 2013 11:45, Devrim GÜNDÜZ <devrim at gunduz.org> wrote:
>>> Hi,
>>> On Wed, 2013-11-13 at 11:39 +0000, Paulo Frias wrote:
>>> > I'm trying to backup my database (which have postgis extension) into a
>>> > new one with pg_dump.
>>> > When I do the pg_restore it gave me a lot of errors and the new
>>> > created database was empty.
>>> What are the errors? Did you install PostGIS extension to the new
>>> database prior to restore?
>>> Regards,
>>> Devrim GÜNDÜZ
>>> Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
>>> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
>>> Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
>>> http://www.gunduz.org  Twitter: http://twitter.com/devrimgunduz
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> *Paulo Frias*
>> Marine Biologist
>> CCMAR - Centre of Marine Sciences
>> ISPA - Instituto Superior de Psicologia Aplicada
> *Paulo Frias*
> Marine Biologist
*Paulo Frias*
Marine Biologist
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131113/4ca48ac0/attachment.html>
