[postgis-users] Grid of points inside Polygon
Rémi Cura remi.cura at gmail.com
Fri Nov 15 02:50:42 PST 2013
Yep, maybe something like
UPDATE ukmajrdbuffer SET the_geom = ST_MakeValid(the_geom)
WHERE ST_IsValid(the_geom) = FALSE
Cheers,
Rémi-C
2013/11/15 James David Smith <james.david.smith at gmail.com>
> Hi Remi,
> Thanks for your continued guidance with this big data problem.  I
> wasn't in the office yesterday so am looking at it again now. I've
> just ran the below below query running, and will let you know how many
> rows there are once it's finished.
> CREATE TABLE lines_for_each_road AS
> WITH all_lines AS (
> SELECT *
> FROM all_lines
> SELECT row_number() over() AS id--,*
> FROM ukmajrdbuffer, all_lines
> WHERE ST_Intersects(ukmajrdbuffer.geom, all_lines.the_geom)=TRUE;
> In the meantime however, I have noticed something else that is a
> worry. I did this:
> SELECT st_isvalid(geom) FROM ukmajrdbuffer;
> NOTICE:  Ring Self-intersection at or near point 367541.09074241668
> 311890.25257437676
> NOTICE:  Ring Self-intersection at or near point 209901.50000000186
> 706890.50000000373
> NOTICE:  Ring Self-intersection at or near point 444961.46434461698
> 161217.66612910852
> NOTICE:  Ring Self-intersection at or near point 559818.64931676909
> 103089.14606037363
> NOTICE:  Ring Self-intersection at or near point 420114.82424666081
> 298567.38722311892
>  st_isvalid
>  f
>  f
>  t
>  f
>  f
>  f
>  t
>  t
> (8 rows)
> I guess that I should try to fix these geometries first before we
> attempt to continue any further right?
> Thanks
> James
> On 13 November 2013 18:04, Rémi Cura <remi.cura at gmail.com> wrote:
> > All lines should be in one table, you can add a column to differentiate
> > between line going SN and EW,
> > this is what the query I wrote does.
> > Not changing your code much, it gives for the line table :
> > CREATE TABLE all_lines tablespace jamestabs AS
> > ( SELECT st_setsrid(st_makeline(st_makepoint(x, 7780), st_makepoint(x,
> > 1226580)),27700) as the_geom, 'SN' AS direction
> > FROM generate_series(53320::int, 667380::int, 20) as x)
> > UNION
> > ( SELECT st_setsrid(st_makeline(st_makepoint(53320, y),
> > st_makepoint(667380, y)),27700) as the_geom, 'EW' AS direction
> > FROM generate_series(7780::int, 1226580::int, 20) as y)
> > then building index on it.
> > "-- Merge the road buffer polygons into one big polygon
> > -- Should maybe consider leaving them as they are, but am merging for
> now.
> > SELECT st_union(geom) as geom INTO union_roads FROM ukmajrdbuffer;"
> > You must not do it !
> > As I told you "blabla index blabla".
> > instead, create an index on table ukmajrdbuffer, and use it without
> > unioning.
> > Then you query is not going to work at all ... (or *very very* slowly)
> > "FROM east_to_west, north_to_south, buff_union_roads" : it potentially
> > generates 1000*50*1000*50 * number_of_road rows to filter, very bad idea,
> > you'll get the same problem as with points...
> > (please see some example on internet to understand WITH, it is simple ,
> > useful, and makes query much more clear)
> > First you could try :
> > CREATE TABLE lines_for_each_road tablespace jamestabs AS
> > WITH all_lines AS ( --this subquerry gets all the lines
> > SELECT *
> > FROM all_lines
> > WHERE ST_Intersects(ukmajrdbuffer.the_geom, all_lines.the_geom)=TRUE;
> > This will give you (if you uncomment the "--,*", ), for every road, all
> the
> > lines intersecting the road
> > example :
> > road_1 | line_2_EW
> > road_1 | line_3_EW
> > road_1 | line_78_SN
> > road_1 | line_7_EW
> > road_2 ...
> > How long is it (don't uncomment plz), and how many rows do you get
> (select
> > count(*) from lines_for_each_road )?
> > If it is not too long, we will go on and "cut" the lines so that for
> every
> > road, we keep the part of the lines that are inside the road_buffer.
> > (I have to leave now, tomorrow)
> > Cheers,
> > Rémi-C
> > 2013/11/13 James David Smith <james.david.smith at gmail.com>
> >> Hey Remi,
> >> I don't quite get what the query you gave does to be honest. But
> >> working with some of the ideas and notions you gave me I have put the
> >> below together. The final bit of the code is the key query. The tables
> >> of NS and EW lines were done very quickly. Nice. But now doing the
> >> 'intersects within polygon' is taking some time so I'll see how it
> >> gets on when I get in to work tomorrow morning:
> >> DROP TABLE IF EXISTS north_to_south;
> >> DROP TABLE IF EXISTS east_to_west;
> >> -- Make a table of north to south lines
> >> CREATE TABLE north_to_south tablespace jamestabs AS
> >> FROM generate_series(53320::int, 667380::int, 20) as x);
> >> -- Add an index
> >> CREATE INDEX north_to_south_geom_index ON north_to_south USING GIST (
> >> the_geom );
> >> -- Make a table of east to west lines
> >> CREATE TABLE east_to_west tablespace jamestabs AS
> >> FROM generate_series(7780::int, 1226580::int, 20) as y);
> >> -- Add an index
> >> CREATE INDEX east_to_west_geom_index ON east_to_west USING GIST (
> the_geom
> >> -- Import the Road Buffer file using the pg_loader interface
> >> -- Update the geometry field as the loader didn't seem to do this.
> >> SELECT UpdateGeometrySRID('ukmajrdbuffer','geom',27700);
> now.
> >> -- The unioned roads file isn't valid geom. So I simplify it a little
> >> to make it valid.
> >> -- We simplify with a 70 metres factor. Geom is now valid.
> >> SELECT ST_SimplifyPreserveTopology(geom, 70) AS geom INTO
> >> buff_union_roads FROM union_roads;
> >> -- Now calculate the points where the lines intersect and also where
> >> they are within the polygon.
> >> CREATE TABLE gridpoints tablespace jamestabs
> >> AS (SELECT ST_Intersection(east_to_west.the_geom,
> north_to_south.the_geom)
> >> WHERE st_within(buff_union_roads.geom,
> >> ST_Intersection(east_to_west.the_geom, north_to_south.the_geom)) =
> >> TRUE);
> >> Thanks
> >> James
> >> On 13 November 2013 13:33, Rémi Cura <remi.cura at gmail.com> wrote:
> >> > Using the lines you exactly do the same as with points.
> >> > The lines will be spaced exactly by 20 meters, end and start being
> >> > exactly
> >> > on the 20 meters grid, line being either perfectly veritcla or
> perfectly
> >> > horizontal.
> >> > So intersections are guaranteed to be on the 20 meter grid, because
> this
> >> > is
> >> > the definition of a 20 meter grid =) .
> >> > Here is a not optimal way to do it :
> >> > For instance if UK is enclosed in a bouding box (xmin,ymin,xmax,ymax),
> >> > where
> >> > xmin-max and ymin-max are rounded to the nearest 20 meters multiple
> (ie
> >> > x or
> >> > y % 20 = 0)
> >> > (Please note that this is not clever because we generate too much SN
> >> > lines,
> >> > GB being only 500 km wide at most, so we would need to filter, but you
> >> > don't
> >> > care, following would take less than a minute anyway, and you need to
> do
> >> > it
> >> > only once).
> >> > WITH minmax AS (
> >> > SELECT xmin,ymin,xmax,ymax, bbox_of_england
> >> > WITH series AS (
> >> > SELECT s
> >> > FROM generate_series(0,1000*(1000/20)::bigint,20) AS s --casting to
> >> > bigint
> >> > to be safe against going over int limit
> >> > WITH lines AS (
> >> > SELECT ST_MakeLine
> (ST_MakePoint(xmin+s,ymin),ST_MakePoint(xmin+s,ymax))
> >> > AS
> >> > lineSN,
> >> >  ST_MakeLine(ST_MakePoint(xmin, ymin+s), ST_MakePoint(xmax,ymin+s) AS
> >> > lineEW
> >> > FROM series, minmax
> >> > unioned_lines AS (
> >> > SELECT lineSN AS line, 'SN' as direction
> >> > FROM lines,minmax
> >> > WHERE ST_Interesects(lineSN,bbox_of_england)= TRUE
> >> > UNION
> >> > SELECT lineEW AS line, 'EW' AS direction
> >> > FFROM lines,minmax
> >> > WHERE ST_Interesects(lineEW,bbox_of_england)= TRUE
> >> > SELECT row_number() over() AS uid, line, direction
> >> > FROM unioned_line
> >> > then creating table and index on geom and on direction (and possibly
> on
> >> > uid,
> >> > but better create a primary key then if you use it)
> >> > Of course I didn't test this query, but you should be able to use it
> >> > easily.
> >> > Cheers,
> >> > Rémi-C
> >> >> Hi Remi,
> >> >> Apologies.  One more thing which I am not sure about. We need the
> >> >> final grid of points that we make to be multiples of 20. For example:
> >> >> 53320, 7780 = Yes
> >> >> 53323, 7780 = No
> >> >> 53320, 7794 = No
> >> >> 53321, 7754 = No
> >> >> That is why in the original function that we wrote, we put the
> numbers
> >> >> in as below.
> >> >> SELECT ST_Collect(st_setsrid(ST_POINT(x,y),$3)) FROM
> >> >> generate_series(53320::int, 667380::int,$2) as x
> >> >> ,generate_series(7780::int, 1226580::int,$2) as y
> >> >> where st_intersects($1,st_setsrid(ST_POINT(x,y),$3))'
> >> >> We did this because the points in the grid have to 'align' with the
> >> >> values of mutliple 20.
> >> >> If we do the N-S and E-W lines solution that you suggest, I don't
> >> >> think that this will work will it?
> >> >> Thanks
> >> >> James
> >> >> On 13 November 2013 11:49, James David Smith
> >> >> <james.david.smith at gmail.com> wrote:
> >> >> > Hi Remi,
> >> >> > Thanks so much for this detailed response. Your idea about creating
> >> >> > the lines and the only storing where they intersect and are within
> >> >> > the
> >> >> > polygons is a great idea. I'm going to give that a go now.
> >> >> > Thanks again,
> >> >> > James
> >> >> > On 13 November 2013 11:41, Rémi Cura <remi.cura at gmail.com> wrote:
> >> >> >> This would be an improvement but still non efficient.
> >> >> >> you have 2 possibilities, supposing that what you want is points
> 20
> >> >> >> meter
> >> >> >> spaced in all road_buf  :
> >> >> >> either you compute for each road_buffer the points inside, one
> road
> >> >> >> at
> >> >> >> a
> >> >> >> time ( figuratively ).
> >> >> >> This means you write a function which generates points 20-meter
> >> >> >> spaced
> >> >> >> in
> >> >> >> the bounding box of the road you are working on, and keep those in
> >> >> >> the
> >> >> >> real
> >> >> >> road buffer, and group result points as a multipoints (for
> cosmetic
> >> >> >> purpose)
> >> >> >> You would then use it like this :
> >> >> >> SELECT road_id, points_insidea_road(the_geom) AS
> >> >> >> my_points_inside_the_road
> >> >> >> FROM road_polygons_table
> >> >> >> You would have as output a line per road with a multipoint
> >> >> >> containing
> >> >> >> all
> >> >> >> the point 20 meter spaced inside the road.
> >> >> >> Or (what you wrote) you generate all points and keep those
> >> >> >> intersecting
> >> >> >> one
> >> >> >> or many road.
> >> >> >> The first one is mandatory, because it avoids to manipulate
> >> >> >> (incredibly) big
> >> >> >> table of all points spaced by 20 meters for UK (around 500 * 10^6
> >> >> >> points ! )
> >> >> >> Even with indexes it's not a good idea to use such number of rows.
> >> >> >> That's the first point (write a function working for one road,
> then
> >> >> >> use
> >> >> >> it
> >> >> >> for all road).
> >> >> >> The second point is the way you compute is very inefficient. If
> your
> >> >> >> road is
> >> >> >> going from south-West to NorthEast, you will generate a very big
> >> >> >> number
> >> >> >> of
> >> >> >> points, and very few will be in the road_buffer. This is
> problematic
> >> >> >> as
> >> >> >> for
> >> >> >> a road of only 20 kms, you may generate as many as 100k points and
> >> >> >> keep
> >> >> >> only
> >> >> >> few of them. If you want to process hundreds of ks or roads it
> will
> >> >> >> become
> >> >> >> very problematic. Also you would have to generate points each
> time.
> >> >> >> So here is what  I suggest you : change your strategy :
> >> >> >>  instead of generating all point in bounding box and then keeping
> >> >> >> only
> >> >> >> those
> >> >> >> in road_buffer,
> >> >> >> generate a line every 20 meters going North south and an line
> every
> >> >> >> 20
> >> >> >> meters going East-West , then use the function ST_Intersection to
> >> >> >> keep
> >> >> >> only
> >> >> >> part of this lines being inside the road_polygon, then you have
> the
> >> >> >> points
> >> >> >> inside road_polygons as the intersections of these EW lines with
> the
> >> >> >> SN
> >> >> >> lines.
> >> >> >> It will be very efficient because you can create a table with all
> >> >> >> the
> >> >> >> lines
> >> >> >> going East-West and South-North for great britain (about 25k + 50k
> >> >> >> lines),
> >> >> >> and build index on it (index on geom and on the column saying if
> it
> >> >> >> is
> >> >> >> SN or
> >> >> >> EW).
> >> >> >> The trick is the number of lines is around 500km * 50 line/km +
> >> >> >> 1000km
> >> >> >> * 50
> >> >> >> line/km , where the number of points is  500km * 50 line/km *
> 1000km
> >> >> >> 50
> >> >> >> line/km
> >> >> >> Hope it helps,
> >> >> >> Cheers,
> >> >> >> Rémi-C
> >> >> >>> Hey Remi,
> >> >> >>> Thanks for your reply. So in your mind you think we should have a
> >> >> >>> database of say 300 polygons, and then we run a command like this
> >> >> >>> right?
> >> >> >>> SELECT
> >> >> >>> ST_Collect(st_setsrid(ST_POINT(x,y),27700))
> >> >> >>> FROM
> >> >> >>> generate_series(53320::int, 667380::int,20) as x,
> >> >> >>> generate_series(7780::int, 1226580::int,20) as y,
> >> >> >>> road_polygons_table
> >> >> >>> WHERE
> >> >> >>> st_intersects(road_polygons_table.the_geom,
> >> >> >>> What do you think?
> >> >> >>> Thanks
> >> >> >>> James
> >> >> >>> On 11 November 2013 14:51, Rémi Cura <remi.cura at gmail.com>
> wrote:
> >> >> >>> > Hey,
> >> >> >>> > the whole point on using a sgbds like postgis is using index.
> >> >> >>> > If you have one line you don't use indexes...
> >> >> >>> > So in short, don't make one polygon with a buffer of all the
> >> >> >>> > road,
> >> >> >>> > but a
> >> >> >>> > table with a line for the buffer for every road, then do you
> >> >> >>> > computation
> >> >> >>> > to
> >> >> >>> > create grid of points inside of polygons, then union the result
> >> >> >>> > of
> >> >> >>> > points!
> >> >> >>> > And it s always a bad idea to run a function on big data when
> you
> >> >> >>> > have
> >> >> >>> > not
> >> >> >>> > tested it fully (including scaling behavior) on small data.
> >> >> >>> > Cheers
> >> >> >>> > Rémi-C
> >> >> >>> > 2013/11/11 James David Smith <james.david.smith at gmail.com>
> >> >> >>> >> Hi all,
> >> >> >>> >> Would appreciate some advice on the best way to accomplish
> this
> >> >> >>> >> please.
> >> >> >>> >> Our situation is that we have a single polygon which has been
> >> >> >>> >> created
> >> >> >>> >> by buffering all of the major roads in the UK. Projection is
> >> >> >>> >> OSGB36
> >> >> >>> >> (27700). Obviously it's quite a big polygon.
> >> >> >>> >> -->  SELECT st_area(geom) FROM roadbufferunion;
> >> >> >>> >>      st_area
> >> >> >>> >>  77228753220.8271
> >> >> >>> >> What we now want to do is create a regular grid of 20 metre x
> 20
> >> >> >>> >> metre
> >> >> >>> >> points instead the polygon area. So we wrote this function
> >> >> >>> >> (based
> >> >> >>> >> on
> >> >> >>> >> some googling, apologies for not being able to recall the
> exact
> >> >> >>> >> person
> >> >> >>> >> who originally wrote it):
> >> >> >>> >> CREATE OR REPLACE FUNCTION makegrid(geometry, integer,
> integer)
> >> >> >>> >> RETURNS geometry AS
> >> >> >>> >> 'SELECT ST_Collect(st_setsrid(ST_POINT(x,y),$3)) FROM
> >> >> >>> >> LANGUAGE sql
> >> >> >>> >> and we then run this by doing the following:
> >> >> >>> >> SELECT st_x((ST_Dump(makegrid(geom, 20, 27700))).geom) as x,
> >> >> >>> >> st_y((ST_Dump(makegrid(geom, 20, 27700))).geom) as y INTO
> >> >> >>> >> grid_points
> >> >> >>> >> from roadbufferunion;
> >> >> >>> >> However after over 2 days of the query running on a pretty
> >> >> >>> >> powerful
> >> >> >>> >> linux cluster, we still have no result.  I'm not sure if it is
> >> >> >>> >> actually running or not to be honest.
> >> >> >>> >> Does the query look right?
> >> >> >>> >> Any ideas how we can make it run quicker?
> >> >> >>> >> Thanks
> >> >> >>> >> James
> >> >> >>> >> _______________________________________________
> >> >> >>> >> postgis-users mailing list
> >> >> >>> >> postgis-users at lists.osgeo.org
> >> >> >>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131115/02677f54/attachment.html>
