[postgis-users] missing libxml2.la file when compiling PostGIS 2.1.1 from Source on Ubuntu 12.04
Richard Greenwood richard.greenwood at gmail.com
Mon Nov 18 17:26:06 PST 2013
Have you tried
   locate xml2-config
and then
  ./configure
--with-xml2config=/whatever/path/to/xml2-config/you/got/from/locate
On Mon, Nov 18, 2013 at 12:44 PM, Paolo Corti <pcorti at gmail.com> wrote:
> On Mon, Nov 18, 2013 at 8:25 PM, Marcelo Soares Souza
> <marcelo at juntadados.org> wrote:
> >> 2.8.0+dfsg1-5ubuntu2.2~precise1
> >   Did you installed libxml2-dev package?
> As mentioned in my previous email:
> On Mon, Nov 18, 2013 at 8:22 PM, Paolo Corti <pcorti at gmail.com> wrote:
> > The libxml2 and libxml2-dev versions I am using is the one from ubuntu
> > precise repository:
> also
> > Note: I can successfully compile PostGIS 2.0.2 in the same machine
> The only stuff I found on the web regarding this missing libxml2.la
> file is here:
> http://forums.gentoo.org/viewtopic-t-925630-start-0.html
> Thanks anyway
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Richard Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131118/41f40245/attachment.html>
