[postgis-users] Finding Islands
Rémi Cura
remi.cura at gmail.com
Thu Nov 21 04:28:25 PST 2013
Hey ,
Oops,
vocaulary error
"because it's making (2 million)^2 comparisons." -> it's cartesian product.
basically you want to compare every polygon to every other, this is a
cartesian product, and this is what takes time.
Choosing wel the function used (touches or intersects or ...) won't change
much computing time as long as it uses index.
In the same way, the logic you do after is not what takes time.
Maybe you should not use the NOT IN syntaxe, but instead a where, or
better, an "except", this should work much better
http://www.postgresql.org/docs/9.3/static/queries-union.html
Cheers,
Rémi-C
2013/11/20 Lee Hachadoorian <Lee.Hachadoorian+L at gmail.com>
> Thank you for these suggestions. I haven't replied yet because I am
> testing them, and the queries take an hour or more to run on the 2 million
> plus table. I will report back with some results.
> On Wed, Nov 20, 2013 at 4:46 AM, Rémi Cura <remi.cura at gmail.com> wrote:
>> Maybe you can try the stupidest way to go,
>> anyway you have to do a inner product because you have to consider each
>> pair of polygons.
> You don't have to do inner product. `a LEFT JOIN b ... WHERE b.gid IS
> NULL` is a typical unmatched query. By doing self join ON ST_Touches(), the
> polygons with no neighbors are returned because the LEFT JOIN returns all
> records from a, while ST_Touches() produces no match (because a polygon
> doesn't touch itself) so b.gid IS NULL.
>> CREATE TABLE result AS
>> SELECT DISTINCT ON (a.gid) a.*
>> FROM table AS a , table AS b
>> WHERE ST_Intersects(a.geom, b.geom) = TRUE
>> AND a.gid != b.gid
> Just to be clear, this produces the polygons *with* neighbors, which is
> why I use this as a subselect with gid NOT IN (...)
> Still testing,
> --Lee
>> Now you can improve, because in the previous query you will compute
>> (geom1,geom2) and (geom2,geom1), which is duplicate
>> so you can try creating an index on gid , and
>> CREATE TABLE result2 AS
>> WITH direct_comp AS (SELECT a.gid AS agid, a.geom AS ageom , b.gid AS
>> bgid, b.geom AS bgeom
>> AND a.gid < b.gid)
>> SELECT agid AS gid, ageom AS geom
>> FROM direct_comp
>> UNION
>> SELECT bgid AS gid, bgeom AS geom
>> FROM direct_comp
>> Now if you want to go really big, this will be difficult.
>> Assuming your polygons bboxes have a homogenous size and/or are not too
>> big reguarding the total area .
>> The idea is to group polygons into same cells, so when you try to find
>> which polygons intersects, instead of comparing a polygon to each other
>> polygon, you compare a polygon to each other polygon in the same cell.
>> create a grid of cells (big enough or you will have lot's of cells)
>> index the table
>> for each cell, get polygons intersecting it. This defines groups of
>> polygons in the same cell, defined by a new id "group_id"
>> index "group_id"
>> Now you will have several options depending on your hardware/data
>> 1) process a cell at a time if limited hardware, adding "WHERE
>> group_id=XX"
>> 2) do a massiv inner join on the group_id and compute all
>> In fact you could avoid to create explicitly the cells, but it will be
>> more complicated.
>> Cheers,
>> Rémi-C
>> 2013/11/20 Brent Wood <pcreso at pcreso.com>
>>> I figure you have spatially indexed the polygons already?
>>> Any way of pre-categorising your polygons - binning them in some way
>>> that allows a non spatial test in the where clause to replace the spatial
>>> test...
>>> eg: a boolean attribute set to indicate if a feature has any part <= a
>>> particular x value or not.
>>> run this against the 2m features once to populate it, and assuming you
>>> get a 50/50 split of T/F features, your 2m^2 query can instead include a
>>> "where a.bool = b.bool", as we already know that if the boolean flag is
>>> different, they cannot touch, so your query should involve a spatial test
>>> only over 1m^2 instead... if you do this on both x & y, the boolean filter
>>> will replace even more spatial calculations & drop them to 500,000^2
>>> tests...
>>> If you can pre-classify features so that non-spatial tests can reduce
>>> the spatial ones (esp for features with lots of vertices) in a where
>>> clause, such queries do run much faster, but you have the trade-off of the
>>> time taken to carry out the classification... which is only n*no_classes/2,
>>> generally much faster than n^n
>>> Hope this makes sense...
>>> Brent Wood
>>> *From:* Lee Hachadoorian <Lee.Hachadoorian+L at gmail.com>
>>> *To:* PostGIS Users <postgis-users at postgis.refractions.net>
>>> *Sent:* Wednesday, November 20, 2013 8:52 PM
>>> *Subject:* [postgis-users] Finding Islands
>>> I am trying to find "islands", polygons in a (multi)polygon layer which
>>> are not connected to any other polygons in the same layer. What I came
>>> up with runs in a couple of seconds on a layer with ~1000 geometries,
>>> and a couple of minutes on a layer with ~23,000 geometries, but I want
>>> to run it on a layer of 2 million+ and it's taking a L-O-O-O-NG time,
>>> presumably because it's making (2 million)^2 comparisons.
>>> What I came up with is:
>>> SELECT a.*
>>> FROM table a LEFT JOIN table b
>>> ON (ST_Touches(a.geom, b.geom))
>>> WHERE b.gid is null
>>> or
>>> SELECT *
>>> FROM table
>>> WHERE gid NOT IN (
>>> SELECT DISTINCT a.gid
>>> FROM table a JOIN table b
>>> ON (ST_Intersects(a.geom, b.geom) AND a.gid != b.gid)
>>> The first variant raises "NOTICE: geometry_gist_joinsel called with
>>> incorrect join type". So I thought I could improve performance with an
>>> INNER JOIN instead of an OUTER JOIN, and came up with the second
>>> variant, and it does seem to perform somewhat better. Any suggestions
>>> for how to speed up either approach?
>>> Best,
>>> --Lee
>>> Lee Hachadoorian
>>> Assistant Professor in Geography, Dartmouth College
>>> http://freecity.commons.gc.cuny.edu
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Lee Hachadoorian
> Asst Professor of Geography, Dartmouth College
> http://freecity.commons.gc.cuny.edu/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131121/f2e3c684/attachment.html>
