[postgis-users] simplifying (homogenize) a polygon
Denis Rouzaud denis.rouzaud at gmail.com
Thu Nov 21 04:50:59 PST 2013
Hi Nicolas,
I edit my multi polygons in QGIS, and you're right the geometry becomes
invalid if some parts have adjacent segments.
In a simple case, I would have a multi polygons with 3 parts with 2
parts adjacent.
http://imgur.com/zvxPFeR
Although the geometry is invalid, my intention is to make it valid, and
therefore merge the two parts, which is impossible in QGIS - AFAIK.
So my intention was to save the geometry as this, and make it valid by a
command.
I could achieve this with a function:
CREATE OR REPLACE FUNCTION distribution.simplemultipoly(geom geometry)
RETURNS geometry AS
$BODY$
     DECLARE
         num_geom integer;
     BEGIN
         SELECT ST_NumGeometries(geom) into num_geom;
         SELECT
ST_Multi(ST_CollectionHomogenize(ST_Union(ST_GeometryN(geom,n))))
             FROM generate_series(1,num_geom) n
             INTO geom;
         RETURN geom;
     END;
$BODY$
LANGUAGE plpgsql;
But I wondered if there was a more direct way.
Cheers,
Denis
On 21. 11. 13 12:42, Nicolas Ribot wrote:
> Hi Denis,
> In your example, I don't understand how the parts of your
> multipolygons can be adjacent. Are they valid ?
> Do you have a visual example ?
> Thank you
> Nicolas
> On 21 November 2013 07:32, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>> Hello Rémi,
>> I was hoping a simplest request without enabling topology but thanks anyway!
>> Cheers,
>> Denis
>> On 20. 11. 13 18:26, Rémi Cura wrote:
>>  From what I understand of your needs, Postigs topology was designed for
>> this.
>> Cheers,
>> Rémi-C
>> 2013/11/20 Denis Rouzaud <denis.rouzaud at gmail.com>
>>> Hi all,
>>> I am drawing some multipolygons in QGIS and sometimes, I have parts of
>>> them which are adjacent and I'd like to homogenize them to have less parts
>>> and no adjacent parts.
>>> I could do this with a quite complex method:
>>> 1. get the number of parts Z:
>>> SELECT ST_NumGeometries(geometry) FROMmytable WHERE id=123;
>>> 2. do the simplification using ST_CollectionHomogenize:
>>> SELECT
>>> ST_Multi(ST_CollectionHomogenize(ST_Union(ST_GeometryN(geometry,n)))) FROM
>>> mytable CROSS JOIN generate_series(1,Z) n WHERE id = 123;
>>> 3. update manually the result in the table (copy paste).
>>> Does someone has something more straightforward???
>>> Thanks a lot!
>>> Best regards,
>>> Denis
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131121/e0943ae6/attachment.html>
