[postgis-users] operator && return errors where st_overlaps or st_intersects does not
Sandro Santilli strk at keybit.net
Thu Nov 21 15:34:57 PST 2013
On Thu, Nov 21, 2013 at 07:11:34PM +0100, Huub Fleuren wrote:
> On 11/21/2013 6:37 PM, Sandro Santilli wrote:
> >On Thu, Nov 21, 2013 at 06:01:47PM +0100, Huub Fleuren wrote:
> >>i upgraded to 1.5.8 without succes, where is 1.5.9?
> i guess 1.5.9will come soon
> By the way: i did NOT use make install, because it is an upgrade no?
> Should i run make install? The version upgrade was not reflected in
> postgis_full_version()
Yes, you have to run make install, and run it _before_
loading the scripts upgrader.
--strk;
 ()  ASCII ribbon campaign        - against html e-mail
 /\  http://www.asciiribbon.org   - against proprietary attachments
