[postgis-users] Qgis/Postgis : impossible to open a project
Nicolas Ribot nicolas.ribot at gmail.com
Fri Nov 22 06:08:48 PST 2013
Look at postgresql.conf and search for the "listen" parameter:
it lists hosts that can connect to the backend.
Nicolas
On 22 November 2013 15:05, laurent <lcelati at latitude-geosystems.com> wrote:
> @ Nicolas : i put the CIDR mask after the address in the file. In vain...
> @ Morten : Yes i'm sure : i saved the pg_hba.conf. correctly
> Please find below the error message when i open my qgis project from one of
> remote station :
> <http://postgis.17.x6.nabble.com/file/n5004943/SS_remote_conexion.jpg>
> I notice also that this failure does not generate log into the postgresLog
> folder (on my server station).
> According to you, the problems comes from postgres configuration
> (pg_hba.conf) or rather from qgis project?
>  I remind you that i succeed in loading postgis data from remote station
> (via qgis). But when i try to open the qgis project from another station,
> the error message appears.
> If you have any idea, thank you.
> Regards.
> View this message in context: http://postgis.17.x6.nabble.com/Qgis-Postgis-impossible-to-open-a-project-tp5003712p5004943.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
