[postgis-users] Simple Line Density
Karl Zinglersen karl.zinglersen at gmail.com
Wed Nov 27 08:29:41 PST 2013
I am dealing with the same types of data and issues as Jeff.
My procedure for data clean up is:
1) CSV files into PostGIS as points
1.1) ST_TRANSFORM to projected spatial reference (here EPSG:32621 / UTM
zone 21 N WGS84)
2) ST_MAKELINE to "sub"-lines via PARTITION BY
3) Create a gridded polygon layer in same srid
4) Run equivalent to select cell_id, line_id from cells, lines where
intersects(lines.geom, cells.geom
- but my postgis runs out of memory after a while. And I am sorry to say
Spatial Analyst doesn't.
Is there more memory cheap way to do it in PostGIS (e.g. via the raster
functions - although I haven't found i yet).
Karl
Den onsdag den 26. december 2012 09.58.43 UTC-3 skrev Jeff Adams - NOAA
Affiliate:
> Hi Brent,
> Thanks for the response. I don't think your original response made it into
> my inbox via the list, but now I see it on the website thread. That seems
> like it might be a viable alternative, I just worry about those vessel
> tracks that would be clearly outside of a particular grid cell, but whose
> buffer would bleed over. How did you handle this type of situation?
> Jeff
> On Mon, Dec 24, 2012 at 7:22 PM, <pcr... at pcreso.com <javascript:>> wrote:
>> Jeff,
>> Did you see my reply using vessel tracklines as vectors & a grid in
>> Postgis to do exactly what you describe?
>> Given we were looking at benthic impact, we buffered the tracklines to
>> create polygons representing the swept area of the deployed fishing gear.
>> These were clipped by the cells, & we could generate statistics suca as the
>> cumulative swept area of all tracks with each cell, number of times each
>> cell was crossed, & given the tracklines have a timestamp associated with
>> them, we could also look at the temporal pattern of tracks crossing cells,
>> for things like seasonal impacts & variation between seasons.
>> Cheers,
>>   Brent Wood
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131127/9afa3b5a/attachment-0001.html>
