[postgis-users] Create equally spaced lines within a polygon
Karl Zinglersen
karl.zinglersen at gmail.com
Fri Nov 29 09:25:53 PST 2013
I need to create transect lines across polygons for planning aerial surveys
for musk oxen and caribous in Greenland.
1. In QGIS I have made polygons of the polygon zones for each survey. Each
polygon hold an attribute of spacing value, e.g. 5, 10 and 20 km.
2. Lines must be equally spaced and parallel.
3. Lines must be perpendicular to the polygon centerline.
4. Centerline must run at the longest distance across the polygon - and
consequently the transects run as the shorter distances.
I've attached a hand made sketch, which display the concept.
I've tried this query
SELECT GENERATE_SERIES(FLOOR(ST_YMin(the_polygon))::int , CEILING(ST_YMax(the_polygon))::int,200) y_value, ST_XMin(the_polygon) x_min, ST_XMax(the_polygon) x_max from
(SELECT the_geom AS the_polygon FROM lakes) l
SELECT ST_Intersection(the_geom, the_polygon) AS the_geom FROM
(SELECT the_polygon, ST_Setsrid(ST_MakeLine(ST_MakePoint(x_min, y_value),ST_MakePoint(x_max, y_value) ), ST_Srid(the_polygon)) AS the_geom FROM
(SELECT the_polygon, GENERATE_SERIES(FLOOR(ST_YMin(the_polygon))::int , CEILING(ST_YMax(the_polygon))::int,200) y_value, ST_XMin(the_polygon) x_min, ST_XMax(the_polygon) x_max from
)c
) lines
from gis stackechange
http://gis.stackexchange.com/questions/24064/filling-a-polygon-with-lines-using-postgis
however these transects runs horisontally and don't seem to take into
account the shape and rotation of the polygon centerline.
Should I be able to change the query or should take a different approach?
Karl Zinglersen
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131129/836beb00/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131129/836beb00/attachment.png>
