[postgis-users] st_offsetcurve
franco base frenk.calza at gmail.com
Fri Oct 4 04:13:48 PDT 2013
I resum this post (new offset in my life).
I try the select on that geometry using
"POSTGIS="2.0.3 r11128" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.8.0"
LIBJSON="UNKNOWN" (core procs from "2.0.1 r9979" need upgrade) RASTER
(raster procs from "2.0.1 r9979" need upgrade)"
And the error is
ERROR: GEOSOffsetCurve: IllegalArgumentException: RobustDeterminant
encountered non-finite numbers SQL state: XX000.
Sandro I don't undesrtand if you have the same errror or if it works.
2013/2/27 Sandro Santilli <strk at keybit.net>
> On Wed, Feb 27, 2013 at 06:22:32PM +0100, franco base wrote:
> > Hi Sandro.
> > My version is
> > "POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.7.1, 23
> > September 2009" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
> > LIBJSON="UNKNOWN" TOPOLOGY RASTER".
> > You say that I have to update to POSTGIS=2.0.3?
> Possibly. Try it, if it doesn't fix it, file a ticket.
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131004/17f576b2/attachment.html>
