[postgis-users] st_split
Nicolas Ribot nicolas.ribot at gmail.com
Mon Oct 28 10:32:37 PDT 2013
The points are not on the line, probably due to rounding errors.
st_contains(line, point) returns false.
Nicolas
On 28 October 2013 18:07, franco base <frenk.calza at gmail.com> wrote:
> Hi.
> I have a set of linestring and point on linestring.
> I want cut the linestring on the point.
> I can have n points for one linestring,
> so I use ST_Split
> (insted of ST_Line_Interpolate_Point and ST_Line_Substring)
> but it doesn't work.
> line;geom_line;point;geom_point
> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11764;"0101000020BB0B00005713362F611F37410D996234AF335341"
> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11769;"0101000020BB0B00005EF0DD584620374139BF2762BC335341"
> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11762;"0101000020BB0B0000A5CBC785841F374156A2A33CB1335341"
> ST_GeometryType(St_Split(geom_line, geom_point))
> give "ST_GeometryCollection"
> but
> (ST_Dump(ST_Split(geom_line, geom_point))).geom
> return only 3 linestring (one for record) and the geometry is egual to
> geom_line
> thanks.
> fb
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
