[postgis-users] tile size
Bborie Park dustymugs at gmail.com
Thu Sep 19 19:15:48 PDT 2013
Thanks for the graphs Duncan! My guess is that at the low tile sizes, the
individual round-trip time would be short but the volume of disk i/o is
what's coming into play. The opposite is true for large tile sizes where
the disk i/o volume is decreased but it takes longer for each round-trip.
Having said all that, I'm not willing to suggest that there is one range
appropriate for every user or deployment. Assuming you ran your scripts on
a typical desktop/laptop, I'd agree that the 200 range is an adequate
starting point. If on the other hand you're deploying with more hardware
(lots of RAM [128GB+], large number of disk spindles (DAS, FC SANs), SSDs
or RAM drives), I would expect that curve to look very different.
-bborie
I really need to build a performance test suite...
On Thu, Sep 19, 2013 at 4:55 PM, Duncan Golicher <dgolicher at gmail.com>wrote:
> Here is a simple speed test using R system.time to record the result after
> reloading the same raster with different tile sizes.
> https://dl.dropboxusercontent.com/u/2703650/SpeedTest.html
> Not had any time to anotate or explain the code but the test should be
> easily replicable (at least under Ubuntu). I provide a link to the data
> (which was used in the example on the geostat course). The code only runs
> without modification on Linux as I use system to send commands pasted
> toegether in R to the shell. Also needs unix odbc setting up.
> Note that the point on raster overlay can be beaten easily for speed by
> the extract function in the R raster package. However the polygon overlays
> are now very fast and compare well with any alternative way of getting the
> result. Using PLR to run  R functions within PostGIS is great if you want
> medians, quartiles etc or any other derived property.
> Duncan
> On Thu, Sep 19, 2013 at 4:32 PM, Duncan Golicher <dgolicher at gmail.com>wrote:
>> Out of interest I  quickly checked whether the conclusions still hold for
>> PostGIS2.2.
>> The changes made in ST_Clip, and some other functions including st_value
>> seem to have altered not just the absolute timing (much faster) but also
>> the relative timing of operations as a function of  tile size.
>> Point on raster overlays are now slower when tile size is small (<50
>> pixels), whereas previously there was an almost linear increase with tile
>> size. Bborie may be able to explain why this change has occurred. I will
>> try to add an update to the weblog at some point in order to clarify the
>> sitation. It is GOOD NEWS as apparently there is now a single optimum tile
>> size for both polygon and point overlays and this does seem to lie at
>> around 200 - 300 pixels using the same example as the weblog, although I
>> have not run enough tests to confirm this. I'll try to find time to confirm
>> this.
>> Duncan
>> On Thu, Sep 19, 2013 at 10:36 AM, Pierre Racine <
>> Pierre.Racine at sbf.ulaval.ca> wrote:
>>> You can also have a look at this article from Duncan Golicher if you are
>>> doing raster/vector analysis:
>>> http://duncanjg.wordpress.com/2012/10/30/tile-size-for-raster-vector-overlays-in-postgis/
>>> > -----Original Message-----
>>> > From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
>>> > bounces at lists.osgeo.org] On Behalf Of Stephen Crawford
>>> > Sent: Friday, September 13, 2013 12:34 PM
>>> > To: postgis-users at lists.osgeo.org
>>> > Subject: Re: [postgis-users] tile size
>>> > OK, thanks. I will give that a try.
>>> > On 9/13/2013 12:31 PM, Adam Eskreis wrote:
>>> >       The most common tile size that I've seen in production is 256x256
>>> >       On Fri, Sep 13, 2013 at 10:33 AM, Bborie Park
>>> > <dustymugs at gmail.com> wrote:
>>> >               Steve,
>>> >               There really isn't. What I do recommend is that if your
>>> raster
>>> > data is not going to change over time (and you don't need to replicate
>>> the
>>> > database), load them as out-db rasters. That way, you can easily
>>> change tile
>>> > size within the database with ST_Tile.
>>> >               -bborie
>>> >               On Fri, Sep 13, 2013 at 6:06 AM, Stephen Crawford
>>> > <src176 at psu.edu> wrote:
>>> >                       Hi All,
>>> >                       Is there a rule of thumb for determining the
>>> best tile
>>> > size when tiling a raster?
>>> >                       Thanks,
>>> >                       Steve
>>> >                       Stephen Crawford
>>> >                       Center for Environmental Informatics
>>> >                       The Pennsylvania State University
>>> >                       <tel:814.865.9905>
>>> >       _______________________________________________
>>> >                       postgis-users mailing list
>>> >                       http://lists.osgeo.org/cgi-
>>> > bin/mailman/listinfo/postgis-users
>>> >               http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-
>>> > users
>>> >       http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>> > Stephen Crawford
>>> > src176 at psu.edu
>>> > 814.865.9905
>> Dr Duncan Golicher
>> Investigador Titular,
>> El Colegio de la Frontera Sur, Chiapas,Mexico
>> Mexico tel +52 1 967 137 94 20
>> Skype name duncangolicher
>> Publications: http://www.mendeley.com/profiles/duncan-golicher
>> Senior lecturer, Bournemouth University, UK
>> Centre for Conservation Ecology & Environmental Change
>> School of Applied Sciences
>> Christchurch House rm C218a
>> Fern Barrow
>> Poole (Dorset) BH12 5BB UK
>> Tel. +44 (0)1202 961682
>> For list of publications see Researcher ID:
>> http://www.researcherid.com/rid/B-4240-2009
>> dgolicher at bournemouth.ac.uk
>> dgoliche at ecosur.mx
>> Researcher ID:
> Dr Duncan Golicher
> Fern Barrow
> Researcher ID:
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130919/6dea1e28/attachment.html>
