[postgis-users] installing 2.1
Stephen Crawford src176 at psu.edu
Fri Sep 20 07:02:59 PDT 2013
So at this point is our best option to build postGIS ourselves, pointing
it to our existing GDAL, etc?
Thanks,
Steve
On 9/19/2013 12:37 PM, Stephen Crawford wrote:
> We are running Centos 6, postgres 9.3.  We have GDAL 1.9 installed.
> I'm doing a hard upgrade.  We had postgres 8.4 with postgis 2.0 and it
> was working.
> On 9/19/2013 12:03 PM, Devrim Gündüz wrote:
>> Hi,
>> Is this RHEL 6? If so, raster support is not available due to old
>> gdal version :-(
>> Regards,
>> Stephen Crawford <src176 at psu.edu> wrote:
>>     Now I have added postgis.sql to my new DB, but I can't seem to find
>>     rtpostgis.sql to add raster support.  I expected it to be in
>>     /usr/pgsql-9.3/share/contrib/postgis-2.1/ alongside postgis.sql and
>>     topology.sql, etc.
>>     Any thoughts?
>>     Thanks Again,
>>     Steve
>>     On 9/19/2013 10:36 AM, Stephen Crawford wrote:
>>         That was it, the dynamic link was looking at the remnants of
>>         the previous build. Thanks. On 9/19/2013 4:00 AM, Sandro
>>         Santilli wrote:
>>             On Wed, Sep 18, 2013 at 05:23:29PM -0400, Stephen
>>             Crawford wrote:
>>                 Hi All, In t! he midst of a hard upgrade to 2.1.
>>                 Installed postgres 9.3 and postGIS 2.1. I have
>>                 created a new database. Now when i try to load
>>                 "postgis.sql" into new DB I get this error early on:
>>                 psql:postgis.sql:58: ERROR: could not load library
>>                 "/usr/pgsql-9.3/lib/postgis-2.1.so
>>                 <http://postgis-2.1.so>":
>>                 <http://postgis-2.1.so>: undefined symbol:
>>                 pj_get_spheroid_defn I can see that the library is in
>>                 the correct location. Any thoghts?
>>             Do you have multiple versions of proj4 library installed
>>             on the system ? It looks like PostGIS was built against a
>>             version with the "pj_get_spheroid_defn" function but the
>>             dynamic linker isn't finding that same version. --strk;
>>             postgis-users mailing list postgis-users at lists.osgeo.org
>>             http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>     Stephen Crawford
>>     Center for Environmental Informatics
>>     The Pennsylvania State University
>> Devrim Gündüz
> Stephen Crawford
Stephen Crawford
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130920/49060118/attachment.html>
