[postgis-users] TIGER geocoder
Luma ruby.tahboub at gmail.com
Thu Apr 17 11:52:58 PDT 2014
As I remember, this directory doesn't have to do anything with the location
where postgresql installed. It's used to save scripts and TIGER data.
So after you successfully follow the steps, you'll generate two or more
scripts that help you to download TIGER data from the ftp location then load
it into your database using shape2sql. There's going to be a script for each
state data.
View this message in context: http://postgis.17.x6.nabble.com/TIGER-geocoder-tp5006118p5006129.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
