[postgis-users] PostgreSQL 9.3.4/PostGIS 2.1.1 function
Åsmund Tokheim asmundto at gmail.com
Sat Dec 6 05:07:03 PST 2014
Hi Freddie,
st_scale can work directly on polygons, there is no reason to convert the
polygons to points. So something like
st_setsrid(st_scale(geom,180.0/pi(),180.0/pi()),4326) should work on any
geometry, see http://postgis.net/docs/ST_Scale.html. I kind of fail to see
what you want to achieve with the rapid conversions between text and
geometries like st_astext(geom)::geometry.
On Fri, Dec 5, 2014 at 11:46 PM, Burgess, Freddie <FBurgess at radiantblue.com>
wrote:
>  Will this function work?
> Does this look right
> -- Name: polygon_radiant_to_latLong(geometry); Type: FUNCTION; Schema:
> public; Owner: -
> CREATE OR REPLACE FUNCTION polygon_radian_to_latLong(geom geometry)
> returns geometry[] as
> select array_agg(latlong) from (
> select path,st_astext(geom) as
> "radians",st_setsrid(st_scale(st_astext(geom)::geometry,180.0/pi(),180.0/pi()),4326)
> as "latlong"
>   from ST_DumpPoints($1::geometry) as p) as foo;
> $$ LANGUAGE 'sql';
> ownsdb=# select * from (
> ownsdb(# select path,st_astext(geom) as
> "radians",st_astext(st_setsrid(st_scale(st_astext(geom)::geometry,180.0/pi(),180.0/pi()),4326))
> as "latlong"
> ownsdb(#   from ST_DumpPoints('POLYGON((326454.7 5455793.7,326621.3
> 5455813.7,326455.4 5455796.6,326454.7 5455793.7))'::geometry) as p) as foo;
>  path  |          radians          |
> latlong
>  {1,1} | POINT(326454.7 5455793.7) | POINT(18704476.5122094
> 312593952.904064)
>  {1,2} | POINT(326621.3 5455813.7) | POINT(18714021.9890763
> 312595098.819654)
>  {1,3} | POINT(326455.4 5455796.6) | POINT(18704516.6192551
> 312594119.061824)
>  {1,4} | POINT(326454.7 5455793.7) | POINT(18704476.5122094
> 312593952.904064)
> (4 rows)
> select st_astext(unnest(polygon_radiant_to_latLong('POLYGON((326454.7
> 5455793.7,326621.3 5455813.7,326455.4 5455796.6,326454.7
> 5455793.7))'::geometry)));
> thanks
> *From:* Burgess, Freddie
> *Sent:* Friday, December 05, 2014 5:40 PM
> *To:* PostGIS Users Discussion
> *Subject:* RE: [postgis-users] PostgreSQL 9.3.4/PostGIS 2.1.1 function
> *From:* postgis-users-bounces at lists.osgeo.org [
> postgis-users-bounces at lists.osgeo.org] on behalf of Stephen Mather [
> stephen at smathermather.com]
> *Sent:* Friday, December 05, 2014 4:34 PM
> *Subject:* Re: [postgis-users] PostgreSQL 9.3.4/PostGIS 2.1.1 function
>   Sorry typos and such, try this again:
>  select st_astext(st_setsrid(st_scale(geom,180.0/pi(),180.0/pi()),4326))
> FROM table_containing_polygons;
>  Best,
> Steve
> On Fri, Dec 5, 2014 at 4:30 PM, Stephen Mather <stephen at smathermather.com>
> wrote:
>>  Hi Freddie,
>>  select st_astext(st_setsrid(st_scale('POINT(1
>> 1)'::geometry,180.0/pi(),180.0/pi()),4326)) FROM
>> table_containing_polygon;
>>  Best,
>> Steve
>> On Fri, Dec 5, 2014 at 3:33 PM, Burgess, Freddie <
>> FBurgess at radiantblue.com> wrote:
>>> How would I do this on a polygon?
>>> Thanks
>>> ________________________________________
>>> From: postgis-users-bounces at lists.osgeo.org [
>>> postgis-users-bounces at lists.osgeo.org] on behalf of Paul Ramsey [
>>> pramsey at cleverelephant.ca]
>>> Sent: Thursday, December 04, 2014 6:51 PM
>>> To: PostGIS Users Discussion
>>> Subject: Re: [postgis-users] PostgreSQL 9.3.4/PostGIS 2.1.1 function
>>> I would think that scaling by 180/pi should do the trick in general?
>>> 1)'::geometry,180.0/pi(),180.0/pi()),4326));
>>> P
>>> On Thu, Dec 4, 2014 at 3:24 PM, Burgess, Freddie
>>> <FBurgess at radiantblue.com> wrote:
>>> > Given a polygon geometry with no SRID, the vertices actually in
>>> radians, but
>>> > since the SRID is zero, it looks like Cartesian coordinates, I want
>>> the lat
>>> > long in degrees and not rads.
>>> > Does anyone provide of a function/custom that will return lat/long in
>>> > degrees given the conditions described?
>>> > thanks
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > postgis-users at lists.osgeo.org
>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141206/ee4ee4ba/attachment.html>
