[postgis-users] Fwd: postgis topology strange behavior
Rémi Cura remi.cura at gmail.com
Mon Feb 24 04:13:01 PST 2014
I cannot test your data, but maybe you should trim your digit number :
-99095.34929557323630434 , could be
99095.35
Cheers,
Rémi-C
2014-02-24 13:08 GMT+01:00 Gonçalo Revez <goncalorevez at gmail.com>:
> another image explaining the error attach
> ---------- Forwarded message ----------
> From: Gonçalo Revez <goncalorevez at gmail.com>
> Date: Mon, Feb 24, 2014 at 12:05 PM
> Subject: Fwd: postgis topology strange behavior
> To: postgis-users at lists.osgeo.org
> forgot to attach the files.
> Date: Mon, Feb 24, 2014 at 12:01 PM
> Subject: postgis topology strange behavior
> Hello,
> I'm using the postgis topology with the following example below.
> It inserts three contiguous polygons, but the third has a strange behavior.
> It seems that the polygon doesn't snap totally to the other polygon (with
> model tolerance of 0.1), where he should split the edges and create a node.
> The problem raises two edges "overlapped". (I attach an image showing the
> topology error).
> In fact, using the jts viewer, the third polygon overlaps the first
> polygon, but below the topology model tolerance.
> How is it possible to solve this type of situation or what could be the
> error in example?
> Thanks
> Gonçalo
> --x--
> --drop topology
> select topology.DropTopology('test_topo');
> --create topology
> SELECT CreateTopology('test_topo', 20791,0.1);
> --create topo geometries table
> create table test_topo.area_topo(id serial primary key, bottom boolean);
> --create topo geometry column
> select topology.AddTopoGeometryColumn('test_topo','test_topo',
> 'area_topo', 'topo_geom', 'POLYGON');
> SET search_path TO topology, public, test_topo;
> --insert polygon 1
> insert into test_topo.area_topo(id,topo_geom, bottom)
> select
> 1,topology.toTopoGeom(ST_GeomFromEWKT('SRID=20791;POLYGON((-99221.0688378750346601
> -99577.07580991843133233,-99192.60793616733280942
> -99686.85357364814262837,-99288.83288956005708314
> -99727.51200465914735105,-99380.99199985167069826
> -99768.17043567015207373,-99433.84796016597829293
> -99700.4063839851442026,-99435.20324119967699517
> -99571.6546857836219715,-99349.8205360765568912
> -99570.29940474992326926,-99221.0688378750346601
> -99577.07580991843133233))'), 'test_topo',1,0), true;
> --insert polygon 2
> select
> 2,topology.toTopoGeom(ST_GeomFromEWKT('SRID=20791;POLYGON((-99105.19230949365010019
> -99703.11694605252705514,-99192.60793616733280942
> -99686.85357364814262837,-99221.0688378750346601
> -99577.07580991843133233,-99169.56815859441121574
> -99535.06209787368425168,-99095.02770174089528155
> -99582.49693405319703743,-99017.09904230313259177
> -99629.25412971586047206,-99034.04005522439547349
> -99715.99211587267927825,-99105.19230949365010019
> -99703.11694605252705514))'), 'test_topo',1,0), true;
> --insert polygon 3
> select
> 3,topology.toTopoGeom(ST_GeomFromEWKT('SRID=20791;POLYGON((-99095.34929557323630434
> -99874.08768260208307765,-99180.89702985195617657
> -99864.18215547507861629,-99285.8180822192953201
> -99726.23814240249339491,-99192.60793616733280942
> -99686.85357364814262837,-99105.19230949365010019
> -99703.11694605252705514,-99071.31028365115344059
> -99810.86178823169029783,-99095.34929557323630434
> -99874.08768260208307765))'), 'test_topo',1,0), true;
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140224/d86a0b2d/attachment.html>
