[postgis-users] postgis topology
Ludovic Granjon ludovic.granjon at u-bourgogne.fr
Wed Jan 15 02:25:13 PST 2014
Hi
thanks
With
SELECT ST_IsValid(st_geometryN(geom,1)) FROM ec;
all is true
no problem in qgis
regards
Ludovic
Le 15/01/2014 11:04, Rémi Cura a écrit :
> You can use ST_IsValid() to know if it is "valid" for postgres.
> Even best, you can try to see what it looks like in qgis.
> Cheers,
> Rémi-C
> 2014/1/15 Ludovic Granjon <ludovic.granjon at u-bourgogne.fr
> <mailto:ludovic.granjon at u-bourgogne.fr>>
>     Hello
>     I think, I can do
>     SELECT st_geometryN(geom,1) FROM ec;
>     without error
>     I get
>     "POLYGON((504935.641400002 2310827.805,504952.193899997
>     2310825.6349,504964.4124 2310824.033,504964.191799998
>     2310823.56,504964.037199996 2310822.9832,504963.987400003
>     2310822.5117,504948.949900001 2310822.7941,504940.407399997
>     2310823.3589,504932.090300001 2310824.5769,504931.797399998
>     2310824.7718,504931.360100001 2310824.9757,504930.894100003
>     2310825.1006,504930.735399999 2310825.1239,504929.7368
>     2310825.2555,504929.7368 2310825.8138,504929.847599998
>     2310828.5646,504935.641400002 2310827.805))"
>     Thanks
>     Ludovic
>     Le 15/01/2014 10:47, Christophe Vergon a écrit :
>>     Hello,
>>     Is st_geometryN(r.geomp,1)  a valid geometry ?
>>     Ludovic Granjon a écrit :
>>>     Hello (Bonjour Christophe)
>>>     I don't use french cadastre, only specific archaelogical data.
>>>     Thanks for this, I try but, I don't realy understand how worked
>>>     topogeo_addpolygon.
>>>     If I do :
>>>     CREATE EXTENSION postgis;
>>>     CREATE EXTENSION postgis_topology;
>>>     SET search_path = topology,public;
>>>     I import my layer with QGIS
>>>     SELECT topology.CreateTopology('ec_topo', 27572);
>>>     SELECT
>>>     topology.AddTopoGeometryColumn('ec_topo','public','ec','topo_geom','POLYGON');
>>>     DO $$DECLARE r record;
>>>     BEGIN
>>>       FOR r IN SELECT * FROM ec LOOP
>>>         BEGIN
>>>         SELECT
>>>     topology.TopoGeo_AddPolygon('ec_topo',st_geometryn(r.geom,1),1);
>>>         EXCEPTION
>>>           WHEN OTHERS THEN
>>>             RAISE WARNING 'Loading of record % failed: %', r.id
>>>     <http://r.id>, SQLERRM;
>>>         END;
>>>       END LOOP;
>>>     END$$;
>>>     I have :
>>>     ATTENTION:  Loading of record 1 failed: la requête n'a pas de
>>>     destination pour les données résultantes
>>>     I don't know where I'm wrong
>>>     If you have an idea
>>>     Thanks
>>>     Regards
>>>     Ludovic
>>>     PS : (si j'avais sur que c'était toi qui répondrait, j'aurai
>>>     écrit sur nos forums francophone ;-) )
>>>     Le 15/01/2014 08:25, Christophe Vergon a écrit :
>>>>     Hello, (bonjour)
>>>>     When you udpdate a topology by using a SET statement if a
>>>>     polygon intersect an other you will have this error.
>>>>     If you want to create a topology from polygons try to use the
>>>>     topogeo_addpolygon function, the intersection between two
>>>>     polygons will be a new face.
>>>>     If, as I mean, you use a french survey "cadastre" data set,
>>>>     it's the best way to do that.
>>>>>     Hi all
>>>>>     I try to import a polygon layer to postgis and build topology
>>>>>     with tolerance.
>>>>>     I try something like that
>>>>>     SELECT CreateTopology('ec_topo2', 27572);
>>>>>     SELECT AddTopoGeometryColumn('ec_topo2', 'public', 'ec',
>>>>>     'topogeom2', 'MULTIPOLYGON');
>>>>>     UPDATE ec SET topogeom2 = toTopoGeom(geom, 'ec_topo', 1, 1.0);
>>>>>     But when I do that, I have
>>>>>     ********** Erreur **********
>>>>>     ERREUR: Spatial exception - geometry intersects edge 262
>>>>>     État SQL :P0001
>>>>>     Contexte : fonction PL/pgsql « topogeo_addlinestring », ligne
>>>>>     124 à affectation
>>>>>     SQL statement "SELECT array_cat(edges, array_agg(x)) FROM (
>>>>>     select topology.TopoGeo_addLinestring(atopology, rec.geom,
>>>>>     tol) as x ) as foo"
>>>>>     fonction PL/pgsql « topogeo_addpolygon », ligne 24 à affectation
>>>>>     fonction PL/pgsql « totopogeom », ligne 112 à FOR sur des
>>>>>     lignes de SELECT
>>>>>     fonction PL/pgsql « totopogeom », ligne 94 à affectation
>>>>>     I try to modify the tolerance parameter but it still doesn't work
>>>>>     Have  you a solution for that ?
>>>>>     Thanks a lot
>>>>>     Regards
>>>>>     Ludovic
>>>>>     _______________________________________________
>>>>>     postgis-users mailing list
>>>>>     postgis-users at lists.osgeo.org
>>>>>     <mailto:postgis-users at lists.osgeo.org>
>>>>>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/6cd31d5e/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140115/6cd31d5e/attachment.vcf>
