[postgis-users] ubuntu: package conflict
Denis Rouzaud denis.rouzaud at gmail.com
Wed Jan 22 08:50:40 PST 2014
Hi Rémi,
Thanks for the reply.
I wanted to go to gdal 1.10 to avoid using legacy.sql in postgis
(ogr2ogr in 1.9 can't find getSRID).
But finally, I might go back to gdal 1.9 if I can't get postgis.
I would prefer to avoid compiling on my own...
Cheers,
Denis
On 22. 01. 14 17:44, Rémi Cura wrote:
> Hey Denis,
> What is the problem?
> You don't wan to have an up to date gdal version, or you want to keep
> an old one?
> Cheers,
> Rémi-C
> 2014/1/22 Denis Rouzaud <denis.rouzaud at gmail.com
> <mailto:denis.rouzaud at gmail.com>>
>     Hi,
>     I am a bit struggled with conflicts of packages.
>     I have this sources:
>     [0] pgdg /   PostgreSQL Global Development Group for precise
>     [1] ubuntugis-unstable
>     If I try to
>     apt-get install postgis
>     I get
>     postgis : Depends: libgdal1 (>= 1.9.0) but it is not going to be
>     installed
>     and
>     apt-get install libgdal1
>     leads to
>     The following packages will be REMOVED:
>       gdal-bin libgdal-dev libgdal1-dev libgdal1h python-gdal
>     The thing is that libgdal1 is at version 1.9 on the repo, so I
>     suppose this is why it will remove my gdal-bin (1.10).
>     Any solution for this?
>     Cheers,
>     Denis
>     [0] https://wiki.postgresql.org/wiki/Apt
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140122/37437be4/attachment.html>
