[postgis-users] Removing tiny polygons
Morten Sickel morten at sickel.net
Tue Jan 28 00:01:21 PST 2014
I never used it, but it should be along the lines discussed here:
http://gis.stackexchange.com/questions/49650/merge-polygons-in-postgis
if it is just a few, it should be doable to do manually - I don't know if
it is possible to do automatically in SQL
For each poly with area < some_limit{
   find largest neighboring poly
    // or smallest, or whatever were you are sure you'll get a
well-defined answer
   join the two polys
Morten
Astrid Bjørnerød skrev:
> Is there anyone you have written some sql-code for removing the small
> polygons onto one of the neighbor-polygons ?
> Any stabil functions for this task?
> Astrid
> -----Opprinnelig melding-----
> Fra: postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] På vegne av Tom McCallum
> Sendt: 27. januar 2014 20:48
> Til: morten at sickel.net; PostGIS Users Discussion
> Emne: Re: [postgis-users] Removing tiny polygons
> Thanks Morten.  I wanted the first case, so that helps.
> On Mon, 27 Jan 2014 19:15:18 -0000, Morten Sickel <morten at sickel.net>
> wrote:
>> It depends on what you mean with "remove" - do you want to just have
>> the large polygons without the area that is covered by the small ones
>> or do you want to add the area of the small polygons onto one or more
>> of the larges? (e.g. how one typically wants to handle shiver
>> polygons)
>> In the first case it is as easy as a query like
>> select the_geom where ST_area(the_geom) > ...
>> Morten
>> Tom McCallum skrev:
>>> Hi all,
>>> If I have a polygon geometry field which seems to be made up of a
>>> large number of tiny polygons and some larger ones, what is the best
>>> way to remove polygons below a certain size?  Would I need to
>>> preprocess this and save in a new table/record or can I dynamically
>>> do it?
>>> Thanks
>>> Tom
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
