[postgis-users] Removing tiny polygons
Hugues François hugues.francois at irstea.fr
Tue Jan 28 06:52:13 PST 2014
What you say sounds very weird to me. I don't understand how postgis can consider a multipolygon as a polygon. Could you provide us a test sample of your data ?
Hugues.
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Tom McCallum
Sent: Tuesday, January 28, 2014 3:25 PM
To: morten at sickel.net; PostGIS Users Discussion
Subject: Re: [postgis-users] Removing tiny polygons
Yes I just want the largest polygons.  The problem being that when I simplify the polygon it appears to need a lot more simplification due to these islands rather than if it just did did one mainland polygon ( asGeoJson comes in at 437 polygons rather than 1 polygon).  Not sure why GeoJson can split it into multiple polygons but Dump[] just hands me one.
Was hoping to use ST_Area but currently cannot break down the single polygon.
Interestingly QGIS can, if I do single to multipart it can break down into main landmass and islands.  What might be an equivalent postgis method for doing this?
On Mon, 27 Jan 2014 19:15:18 -0000, Morten Sickel <morten at sickel.net>
wrote:
> It depends on what you mean with "remove" - do you want to just have
> the large polygons without the area that is covered by the small ones
> or do you want to add the area of the small polygons onto one or more
> of the larges? (e.g. how one typically wants to handle shiver
> polygons)
> In the first case it is as easy as a query like
> select the_geom where ST_area(the_geom) > ...
> Morten
> Tom McCallum skrev:
>> Hi all,
>> If I have a polygon geometry field which seems to be made up of a
>> large number of tiny polygons and some larger ones, what is the best
>> way to remove polygons below a certain size?  Would I need to
>> preprocess this and save in a new table/record or can I dynamically
>> do it?
>> Thanks
>> Tom
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
