[postgis-users] hard upgrade of database fails because of tsvector syntax error
Richard Greenwood richard.greenwood at gmail.com
Thu Jan 30 12:24:27 PST 2014
Would it be possible to delete the contents of the to tsvector column
before exporting and rebuild after import?
Sent from my mobile
On Jan 30, 2014 11:06 AM, "Scott Pezanowski" <scottpez at hotmail.com> wrote:
> Sandro,
> Thank you for your advice and I apologize for the lengthy delay in my
> reply. Based on your advice, I seem to have narrowed the problem to one
> record the restore script hits and its tsvector value (perhaps there are
> other records that may fail after this, but the restore fails to get past
> this one). Below is the error I am getting when using postgis_restore.pl.
>   Reading list of functions to ignore...
>   Writing manifest of things to read from dump file...
>   Writing ASCII to stdout...
> ERROR:  syntax error in tsvector: "'2012':5 'call':8 'elect':17
> 'gagnam':12 'hurrican':14 'koni':7 'mayb':10 'olymp':11 'presidenti':16
> 'rt':1 'sandi':15 'stop':6 'style':13 'summari':3 'wt"
> CONTEXT:  COPY twitter_datatable_2012_12, line 46295160, column
> textsearchable_index_col_with_stop: "'2012':5 'call':8 'elect':17
> 'gagnam':12 'hurrican':14 'koni':7 'mayb':10 'olymp':11 'presidenti':16..."
> The actual complete tsvector text is shown below.
> "'2012':5 'call':8 'elect':17 'gagnam':12 'hurrican':14 'koni':7 'mayb':10
> 'olymp':11 'presidenti':16 'rt':1 'sandi':15 'stop':6 'style':13
> 'summari':3 'wtffact':2"
> Therefore, there is more text in the tsvector field, which seems to be
> being truncated. I do not see anything out of the ordinary with any
> characters near where the truncation occurs, that would cause this - Unless
> it is perhaps actually failing somewhere other than at the  'wt  part. Do
> you think there may be a need for some sort of escape of certain characters
> like the apostrophe? Or perhaps a length imposed on the text?
> I am not quite sure what the problem with the data could be. If I simply
> insert the full actual value into the tsvector column, it inserts fine. So
> I think it seems like the text being truncated for some reason causes the
> "syntax error".
> Based upon this, can you see what the problem may be or do you have any
> other suggestions on things I can look at to try to diagnose the problem?
> Thanks again,
> Scott
> > Date: Tue, 7 Jan 2014 18:04:39 +0100
> > From: strk at keybit.net
> > To: postgis-users at lists.osgeo.org
> > Subject: Re: [postgis-users] hard upgrade of database fails because of
> > On Mon, Jan 06, 2014 at 09:03:05PM -0500, Scott Pezanowski wrote:
> > > When I do a straight pg_restore of the dump file into a PostGIS
> database without using the postgis_restore.pl script, the database
> restores fine. Is there any chance I could do this and have the latest
> version of PostGIS 2 work on it as-is? Or could I perhaps load the
> legacy.sql file and then do this?
> > > Is there any way I could modify the postgis_restore.pl script where
> it would accomplish what it needs to do with the PostGIS upgrade, but then
> use the pg_restore command instead of piping the results to psql?
> > > I also have the database dumped as a SQL file. Is there any way I can
> use this and achieve a solid restore to PostGIS 2?
> > What you could do is send the output of "postgis_restore.pl" to a file,
> > and compare it with the output of pg_restore to see where things get
> > messed up.
> > --strk;
> > postgis-users mailing list
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140130/36eefc58/attachment.html>
