[postgis-users] PostGIS non functional on Ubuntu 14.04
Luís de Sousa luis.a.de.sousa at gmail.com
Tue Jul 29 00:44:03 PDT 2014
Hello everyone, here is then the fix to this problem:
$ sudo rm /usr/local/lib/libgeos_c.so*
$ sudo rm /usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so*
$ sudo ldconfig
$ sudo su postgres
$ /etc/init.d/postgresql restart
$ psql pg_testing -c "create extension postgis"
CREATE EXTENSION
Thank you all for replies that lead here. Best,
Luís
On 28 July 2014 17:42, Rémi Cura <remi.cura at gmail.com> wrote:
> Hmm, no luck :-(
> If you don't want to take any chance,
> don't delete the .so, but rename them (like libgeos_c.so.backup).
> After any change on your lib, you should ldconfig anyway.
> Cheers,
> Rémi-C
> 2014-07-28 17:26 GMT+02:00 António M. Rodrigues <amcrgrodrigues at gmail.com>:
>> Hi,
>> A while back I had a similar problem upgrading from 2.0 to 2.1
>> Going throught my notes I found this which might help:
>> sudo ln -s /usr/lib/postgresql/9.1/lib/postgis-2.1.so
>> /usr/lib/postgresql/9.1/lib/postgis-2.0
>> ldconfig
>> You're basically creating a symbolic link with the older library.
>> Hope it helps,
>> António
>> 2014-07-28 16:10 GMT+01:00 Luís de Sousa <luis.a.de.sousa at gmail.com>:
>>> Hi Mike, thank you for tips.
>>> In fact I have several "old" .so files installed:
>>> $ locate libgeos_c.so
>>> /usr/lib/libgeos_c.so
>>> /usr/lib/libgeos_c.so.1
>>> /usr/lib/libgeos_c.so.1.8.2
>>> /usr/local/lib/libgeos_c.so.1
>>> /usr/local/lib/libgeos_c.so.1.7.1
>>> /usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1
>>> /usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1.7.1
>>> /usr/local/src/geos-3.3.1/capi/.libs/libgeos_c.so.1.7.1T
>>> /usr/share/gvSIG-desktop-2.0.0/gvSIG/extensiones/org.gvsig.raster.tilecache.app/install/files/native/libgeos_c.so.1
>>> /usr/share/gvSIG-desktop-2.0.0/native/libgeos_c.so.1
>>> The problem is that running dpkg only libgeos-3.4.2 shows up:
>>> $ dpkg -l | grep libgeos
>>> ii  libgeos-3.4.2
>>> 3.4.2-4ubuntu1                                      amd64
>>> Geometry engine for Geographic Information Systems - C++ Library
>>> ii  libgeos-c1
>>> Geometry engine for Geographic Information Systems - C Library
>>> ii  libgeos-dev
>>> Geometry engine for GIS - Development files
>>> Meaning that these old .so must be removed manually. In my experience
>>> this always leads to other problems down the road. Any hints on how to
>>> safely remove these old files is welcome.
>>> Another thing: why were these files left in the system, if the
>>> corresponding package is no longer installed? Is this a problem with
>>> the Ubuntu upgrade procedure? Or an issue with the package itself?
>>> Thank you,
>>> Luís
>>> On 28 July 2014 13:19, Mike Toews <mwtoews at gmail.com> wrote:
>>> > On 25 July 2014 20:03, Luís de Sousa <luis.a.de.sousa at gmail.com> wrote:
>>> >> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1310src
>>> > Whoa, someone edited those for "trusty", and are a bit off. I've
>>> > rolled those back to 13.10, and assembled a virtual machine for more
>>> > instructions. Look for more appropriate source build instructions at:
>>> > http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1404src
>>> > And really simple package installation instructions at:
>>> > http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1404pkg
>>> > While I'm unable to reproduce your error from Ubuntu packages, it
>>> > looks like you are on the correct track on removing older libraries of
>>> > lwgeom and geos_c. E.g., a clean install from packages should see
>>> > this:
>>> > -Mike
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > postgis-users at lists.osgeo.org
>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
