[postgis-users] Versioning system to use with QGIS + Postgis
Alexandre Neto senhor.neto at gmail.com
Thu Jun 5 15:28:57 PDT 2014
Hello José,
I already knew about pgversion, but I haven't been able to see its code or
use the plugin.
Do you  know if it is still working?
Thanks,
Alexandre Neto
Em 05/06/2014 18:01, "José Carlos Martínez Llario" <jomarlla at cgf.upv.es>
escreveu:
>  Hi,
> pgversion is a nice approach and there is a QGIS plugin too.
> I tried it a couple of years ago and I liked it.
> It is programmed using plpgsql so you can improve it or study the source
> code easily
> http://www.kappasys.ch
> On 05/06/2014 18:43, Alexandre Neto wrote:
>  Hello all,
>  I have been working on a versioning system to be used with QGIS.
>  This is probably a very naive approach since I'm no expert in Postgres,
> but I would like to ear some comments and suggestions to improve it.
>  The work is based on the versioning system of QGIS, but I wanted to
> improve two things:
>  1 - Keep always the same primary key of features;
> 2 - Only save\backup changed columns instead of the full similar rows;
>  Thanks for your help
>  Alexandre Neto
> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> José Carlos Martínez Llariohttp://cartosig.upv.es
> Producción Cartográfica y SIG.
> Dpto. Ingeniería Cartográfica.
> Univ. Politécnica de Valencia.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140605/855e516a/attachment.html>
